Posted: Tue Jan 01, 2013 7:09 pm Post subject: |
damn beautiful............. _________________ vince
Posted: Wed Jan 02, 2013 1:07 am Post subject: |
Very nice looking wheels oily  _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sat Jan 12, 2013 8:31 pm Post subject: |
My way of locking the nut.
Posted: Sat Jan 12, 2013 8:40 pm Post subject: |
...The proper way
are you going to use the center locking bolt too?
...it's actually redundant now and will save weight too  _________________ SB6 mk1 (project mega light, big bore)
Posted: Sat Jan 12, 2013 8:59 pm Post subject: |
| oily wrote: |
...The proper way
...it's actually redundant now and will save weight too  |
No not going to use.
My opinion... the centre bolt is a bad way for securing the nut.
It’s always possible that the centre bolt will run loose.. and if that happens you lose your last line of defence..  _________________ vince
Posted: Sat Jan 12, 2013 9:11 pm Post subject: |
...The proper way of locking things  _________________ SB6 mk1 (project mega light, big bore)
Posted: Mon Jan 21, 2013 9:37 am Post subject: |
| Vince186 wrote: |
This is what I did with the front sprocket cover.
From my humble opinion it isn’t strange that the old cover was broken on that part.
Looking from a mechanical perspective, the corner is too sharp.
A sharp corner gives more chance of cracks.
I leave there material in a large radius so that the forces can better run off.
At the down site there was material that had no function so I removed it.
At the inner site I removed also some material (see the arrows)
I did that to gain some access for the front sprocket.
Now I can remove the front sprocket without removing the cover.
And if I am right it’s now possible to change the sprockets without removing or swing forward the engine.
If I am wrong ,please tell me, maybe I am overlooking something.
This summer we will see if the cover will crack again or will crack on a different place.
Time will tell…
There was still some lateral movement on the clutch cylinder when I pulled the clutch lever.
To possibly prevent metal fatigue to the sprocket cover again I installed a bracket. See pic.
Now there is no movement visible.
The bracket is T6 aluminium. _________________ vince
Posted: Mon Jan 21, 2013 9:46 am Post subject: |
...The Suzuki design team created all those mounting points for a reason then the Bimota design team cut them all off
On the oil cooled, slingshot engine, we used a minimal, billet sprocket cover and that had a minimum of four mounting points.......
wonder if I could get one to fit on the water cooled engine?  _________________ SB6 mk1 (project mega light, big bore)
Posted: Mon Jan 21, 2013 10:22 am Post subject: |
Looks nice, but does that fit in the SB6  _________________ vince
Posted: Mon Jan 21, 2013 10:24 am Post subject: |
| oily wrote: |
...I've always been a touch concerned about Bimota removing altogether the support for the gear change shaft  |
Mine too, but if it was.. a really bad design.. than there were more complains about it on this forum.  _________________ vince
Posted: Mon Jan 21, 2013 10:26 am Post subject: |
Unfortunately No
It's for the earlier oil cooled engine but I'm assuming a similar design could be made for the water cooled engine. Four mounting points is definitely the way forward
I may have a look into a design this afternoon  _________________ SB6 mk1 (project mega light, big bore)
Posted: Mon Jan 21, 2013 10:28 am Post subject: |
| Vince186 wrote: |
| oily wrote: |
Mine too, but if it was.. a really bad design.. than there were more complains about it on this forum.  |
Worst problem I've encountered is a weeping oil seal
Perhaps not such an issue  _________________ SB6 mk1 (project mega light, big bore)
Posted: Mon Jan 21, 2013 10:39 am Post subject: |
| oily wrote: |
| Vince186 wrote: |
| oily wrote: |
Perhaps not such an issue  |
Maybe you have to be gentle when you are shifting gears…
If I’m not gentle to my wife she is also weeping …  _________________ vince
Hursty
Posted: Mon Jan 21, 2013 10:50 am Post subject: |
It's not a Honda no point in being gentle you might miss a gear
Stomp on it and crack the throttle wide open I say  _________________ Hursty from kiwi land  |
