SB6 Forks
Goto page Previous  1, 2, 3, 4, 5, 6, 7
bimota_rider
PostPosted: Fri Sep 20, 2013 3:28 pm    Post subject: Reply with quote
CBar said;
Quote:
A local Race Tech center should be able to take care of it.
Thumbs UP button: PRESSED..... Wink
Thanks.
Built 5/97
2014 Suzuki Hayabusa
2001 BMW R1100S
bimota_rider
PostPosted: Wed Sep 25, 2013 3:27 am    Post subject: Reply with quote
I was worried about my forks "weeping" a bit. Crying or Very sad
Being an "old school" mechanic, I tried an "old school" trick.
Idea Using a stout PAPER business card, I inserted it, corner first, past the dust seal, then past the oil seal and gently slid it all the way around the circumference of the fork tube, at the same time gently moving it up and down. You must keep the card tightly wrapped against the fork tube! This removes (or just moves) any small bits of crud or debris from between the seal and the tube and allows the seal to have a uniform fit all the way around.
IT WORKED!!! The weep is gone and my forks work beautifully. Very Happy
Built 5/97
2001 BMW R1100S
Page 7 of 7
