jakoblt
Posted: Fri Oct 28, 2011 7:35 pm Post subject: |
| Should be all right, if you like the bling bling type. There are lots out there as the same unit exactly is still used today by other manufacturers, Yamaha Aerox 50 scooter, BMW motorcycles also. Same rear light used on a lot of Bims, YB11, DB4 etc. Some folk have bought from china which has combined indicators in the mens and reckon they're OK also |
zombie
Posted: Fri Oct 28, 2011 9:11 pm Post subject: |
| Cagiva raptor too... |
jakoblt
Posted: Sun Oct 30, 2011 12:55 pm Post subject: |
Thanks for the help I think its to bling as well, but the alternative i the original. So if you have some links where I can find some other I would be very happy.
rgds
Jakob |
Posted: Fri Nov 04, 2011 5:13 pm Post subject: |
Is your original broken? Or are you wanting to change it for an LED version?
I'm not sure if the YB9 SR and SRi rear lights are the same. |
jakoblt
Posted: Sat Nov 05, 2011 2:25 pm Post subject: |
thank you very much to all of you.
I am still looking for a light, So if any of you in here have some suggestions I would be very happy
rgds
Jakob |
jakoblt
Posted: Sun Nov 06, 2011 8:39 pm Post subject: |
It look s nice. What are the problem with the electric that you mention? And how have you solved that? And thank you for the suggestion
rgds
Jakob |
Posted: Mon Nov 07, 2011 10:23 am Post subject: |
Electrical connector is not a straight fit to the Bimota wiring. It is supplied with a 3 pin small connector
On the YB11 this was easy, the bike harness was a 3 large pin connector that went straight onto the back of the light. Just a matter of cutting the supplied connector off the light, putting 3 large spade connectors on the wires, and then plugging the individual spade connectors into the YB's multi connector. I guess the yb9 will be similar set up.
The wiring/connectors on the DB4 are better quality, so sealed connectors etc, so a bit more work.
Well within the skill set of the average Bimota owner. |
jakoblt
Posted: Mon Nov 07, 2011 10:39 am Post subject: |
| hahaha yes i guess so. I just changed the original blinkers to some carbon ones in LED nobody told me that I had to fit some more wirering to get it to blink as it should. But got it to work:) |
Posted: Mon Nov 07, 2011 6:49 pm Post subject: |
Are you after a new light because the old one is broken? Or, you just want to change the original to an LED version?  |
jakoblt
Posted: Mon Nov 07, 2011 7:16 pm Post subject: |
It dosent have to be an LED but just one that look more up to date. It looks like its stolen from a moped. So im open for anything  |
jakoblt
Posted: Mon Nov 07, 2011 7:17 pm Post subject: |
And the original is working fine. I just dont like it
rgds
Jakob |
