Power Commander For Db5 Mille
barsrider
PostPosted: Wed Nov 09, 2011 2:54 pm    Post subject: Power Commander For Db5 Mille Reply with quote
Hello,
Do you have any idea which powercommander is suitable for 2006 db5 mille?
Thanks
delirio1100
PostPosted: Fri Dec 23, 2011 9:46 am    Post subject: Reply with quote
I adopted a PC V with autotune to my db6 Very Happy
Any news on the cable issue?
barsrider
PostPosted: Sun Apr 15, 2012 4:20 pm    Post subject: Reply with quote
dignostic cable issue solved...i get it from Rimini Smile
thanks...
talisker
PostPosted: Fri Jul 12, 2013 12:38 pm    Post subject: Reply with quote
Hi Delirio1100,
I have just read that you use the PC V with AutoTune on your Bimota DB6; which model do you use? what ECU map do you use? is the motorbike running fine? better than before?
Many thanks in advance for your help!
