MARTIN
Posted: Sat Dec 03, 2011 12:41 pm Post subject: |
Agree, would admins set up section for a register
Aware this is available on a Swiss Bimota site,but for whatever reason people do not want to register.
Keep it simple type (SB6) FRAME NUMBER (XXXX)
As I am not aware of any year of manufacture on frame or stamp, year of first registration on registration document, (if imported/exported from country to country this may be not available) _________________ Marty
Posted: Sat Dec 03, 2011 1:31 pm Post subject: |
There is of course Chaos Theory which I think came about when some Astro Physicasist broke down in tears over trying sort out the SB6 numbering system and modifications.
Series 1 also (might of) had
GSX-R clocks and brake masters
Dymag H type wheels
Bigger offset front discs
smaller headlights (?)
Solid alloy rearsets
Series 2
Marchesini 3 spoke wheels
Ducati 916 / Yamaha YZF750 discs
"honda style" speedo / clocks
Brembo goldline master cylinders
The rear seat unit was strenghthened (?)
Series 3
Antera wheels
The front forks have optional adjusters at the top which became standard later on. Rasberry Ripple paint on the first series and also red (main colour) and graphite flashes on the series 2.
There was a race kit apparently, titanium exhaust and fork stanchions, uprated Brembo calipers.
The 6R frame lost the bracing to the headstock, the forkbrace swapped sides, the swingarm is stiffer and about 25mm longer.
The SB7's seat unit is different, my SB6 numberplate hanger fits at the back but is narrower at the front (I put an alloy channel section across it) _________________ Don't read everything you believe |
Posted: Sat Dec 03, 2011 5:48 pm Post subject: |
Just the first of dozens of anomalies that pop into my head is that some series 2 were also supplied with Antera wheels |
Posted: Sun Dec 04, 2011 12:26 pm Post subject: |
oily wrote: |
I'm sure your right
I expect Bimota orderred parts as and when ... then yhey'd possibly turn up when the cheque cleared .... and be used as needed. Bikes were probably nailed together form whatever was to hand. _________________ Don't read everything you believe |
Posted: Sun Dec 04, 2011 12:40 pm Post subject: |
Mine is a '96 model, frame number 1165, red and white with antera wheels. i'm not sure how that fits with the series theory?
I like the idea of a register. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
husson73
Posted: Sun Dec 04, 2011 6:03 pm Post subject: |
MARTIN wrote: |
To add more weight to the discussion,consider the following:
Only using the SB6 (not the R) model ,my research (open to others that may know) shown that there was 3 series produced of the SB6, main difference was colour (original, if you have a different colour, frame number-lower or higher may be only reference)
Series 1 WHITE,RED AND CARBON "SB6"LEGEND WAS RED & CARBON
Series 2 DARK GREY AND RED "SB6"LEGEND IN WHITE
Series 3 DARK GREY ONLY "SB6" LEGEND IN WHITE
My research also showed that
SERIES 1 NUMBER PRODUCED 790
SERIES 2 NUMBER PRODUCED 332
SERIES 3 NUMBER PRUDUCED 22 = 1144
I think that number for series 2 & 3 ,due to what may have transpired when factory closed and outlay of materials was being attempted to recoup, may be more.
So let see if this works
Frame numbers 0- 790 original colour series 1 ?
frame numbers 791 -1122 (?) original colour series 2 ?
frame numbers 1123- 1144 (??) original colour series 3 ?
Interested to see response |
Your sequences don't work, and am not really surprise.
My SB6 so call serie 1 white red carbon has frame number SB6008**, my bike has also marchesini wheels from second typ and the modified instruments and the renforced body. |
MARTIN
Posted: Mon Dec 05, 2011 12:05 am Post subject: |
Source:
http://www.bimota-enthusiasts.com/models/sb6/sb6.htm
My one is a Series 2 dark grey/ red, Antera wheels, registered new 2000
frame number 00971
When Bimota bought back all the "duff" V-Dues, wander what they did with them - scrapyard somewhere ???? _________________ Marty
Posted: Mon Dec 05, 2011 9:13 am Post subject: |
I think a small amount of confusion is introduced by the registration dates as well.......
....I also have a Series 2 dark grey/ red, Antera wheels, frame number 1248, so much later than yours Marty BUT registered towards the beginning of 1997.
A sign perhaps of how long some Bimota's hung around at dealers before being sold.
My Red/White/Carbon with who knows what wheels(series 1 or 4?) which has a frame number of just 18 before my series 2 (1230) was not registered until late 1998.
Who knows
husson73
Posted: Mon Dec 05, 2011 12:32 pm Post subject: |
MARTIN wrote: |
Source:
frame number 00971
When Bimota bought back all the "duff" V-Dues, wander what they did with them - scrapyard somewhere ???? |
Martin Bimota enthusiasts hasn't written then the first serie was frame 1 to 790 but only 790 were built.
The duff V dues were bought by pietro when he bought the whole stock of bikes, parts and so on after the bankcrupty |
MARTIN
Posted: Tue Dec 06, 2011 9:50 am Post subject: |
Used info here, and from www.bimota.ch
Looks like my info -other than above frame number 1144 where things go askew- is not far off
SB6 00013 Italy
SB6 00014 Germany Ser 1 red/white
SB6 00018 UK Ser 1 red/white
SB6 00021 Germany Ser 1 red/white
SB6 00064 Italy
SB6 00088 Germany Ser 1 red/white
SB6 00104 Germany
SB6 00128 Germany Ser 1 red/white
SB6 00164 Germany
SB6 00289 Germany
SB6 00299 Germany Ser 1 red/white
SB6 00489 Germany
SB6 00499 UK
SB6 00502 Switzerland Ser 1 red/white
SB6 00503 Switzerland
SB6 00517 UK Ser 1 red/white
SB6 00546 Switzerland
SB6 00553 Switzerland
SB6 00649 Italy
SB6 00697 Switzerland Ser 1 red/white
SB6 00699 Switzerland
SB6 00700 Switzerland Ser 1 red/white
SB6 00701 Italy
SB6 00702 Switzerland
SB6 00703 Switzerland
SB6 00778 Germany
SB6 00787 Italy
SB6 00820 Germany Ser 2 RED Not orig colour
SB6 00910 Italy
SB6 00949 Australia
SB6 00954 Denmark
SB6 00971 UK Ser 2 grey/red
SB6 01069 UK
SB6 01118 Germany
SB6 01141 Norway
SB6 01165 Australia Ser 1 red/white
SB6 01148 Germany
SB6 01183 Italy
SB6 01212 Denmark Ser2 grey/red
SB6 01230 UK Ser2 grey/red
SB6 01248 UK Ser2 grey/red
SB6 01251 Germany
SB6 01261 UK Ser2 grey/red
SB6 01265 Germany _________________ Marty
Posted: Tue Dec 06, 2011 10:01 am Post subject: |
Ummmmmm..........
The plot thickens, both my SB6's are on there but I'm 2 feet away from 1230 at the moment and it aint looking very Red/Grey to me...........
...Now you may say, and I would have been inclined to agree, that it's had a colour/bodywork change but nothing shows up on any of the UK searches including the police data base thingy........
Any hoo, Gather all this information together Marty as Keith is sorting out a register for us so we will be able to sort out some semblance of order to this.....well as much as possible |
