Admin Site Admin
Posted: Fri Nov 07, 2008 12:45 am Post subject: Dieci Sprockets |
I need to source a new C&S for the Dieci. Chain isn't a problem (think it is a 106 link chain, but stock is an odd 532 size), and I have got a rear sprocket made up (530 to make life easy).
However need a front sprocket. Is it the same as the FZR1000, or is it machined to be offset slightly?
Keith |
Posted: Fri Nov 07, 2008 9:31 am Post subject: |
Sorry can't answer your question but if the chain run doesn't line up withe a FZR sprocket, you could always have a spacer machined up to fit behind it. Quite a common fix when building streetfighters/choppers etc  |
jatexup
Posted: Sat Jan 24, 2009 7:23 pm Post subject: Dieci sprocket |
Hi,
As far as I can remember when I had a YB10 and replaced the C&S, I also had a rear made up for me but I think that the from sprocket form an FZR1000 was used which would seem to indicate that this was in fact OK. I only wish I hadn't sold it last year! |
Admin Site Admin
Posted: Sun Jan 25, 2009 1:33 am Post subject: |
Front looks the same. Only thing I have done is go for a 530 C&S rather than the standard 532.
Keith |
YBowner
Posted: Tue Sep 15, 2009 8:11 pm Post subject: Re: Dieci Sprockets |
| Admin wrote: |
Need to do the C&S on my Dieci. Looking to use a TripleS Xring chain; but could you advise on where to get the rear sprocket and if the stock FZR front sprocket works okay? The bike has the standard rear wheel on.
Thanks |
Admin Site Admin
Posted: Mon Nov 02, 2009 6:19 pm Post subject: |
I used a stock FZR front sprocket (in a 530 size rather than the stock Bimota 532 size).
Rear sprocket I had made up by B&C Express from the dimensions I gave them. Must say I was VERY impressed with how quickly they supplied it.
Not sure on how good Triple S chains are.
Keith |
