db4 owner help me please :-)
bimototo
PostPosted: Sun Jan 22, 2012 7:04 pm    Post subject: db4 owner help me please :-) Reply with quote
hi,
has subjetc, I need a help,
someone have some picture of a monoseat model without a tail?
I need to see how is the frame of that version.
i've buy a monocoque of the "old version" and is not plug and play.......Smile
thanks a lot!
PostPosted: Sun Jan 22, 2012 9:09 pm    Post subject: Reply with quote
I have a new DB4 rear subframe in the garage - can take a picture if it helps?
Garry.
bimototo
PostPosted: Sun Jan 22, 2012 9:24 pm    Post subject: Reply with quote
if is for the db4ie i don't need (alredy have) if is for the other model will help a lot Smile
my email is antonio.cocchi@sick.it
PostPosted: Sun Jan 22, 2012 9:39 pm    Post subject: Reply with quote
don't know which model its for, Antonio - the box is marked "DB4".
I will take a photo and send it anyway.
Garry.
bimototo
PostPosted: Sun Jan 22, 2012 9:57 pm    Post subject: Reply with quote
thanks a lot Very Happy
PostPosted: Sun Jan 22, 2012 10:05 pm    Post subject: Reply with quote
Hey Antonio - are you anywhere near Misano Adriatico?
Garry.
bimototo
PostPosted: Sun Jan 22, 2012 10:36 pm    Post subject: Reply with quote
i am very close to Imola almost 80km from misano, i've been in bimota factory just a couple of day ago for have lunch with the marketing mng.
why?
PostPosted: Mon Jan 23, 2012 1:47 pm    Post subject: Reply with quote
Heres a picture of the single seat frame. I have a dual seat frame in the garage. so can put them together for comparison if it helps.
bimototo
PostPosted: Mon Jan 23, 2012 2:21 pm    Post subject: Reply with quote
it will help a lot Smile
can you please mail me a big size picture?
and also of in not a problem can you send me the measure of that frame Smile vero vrty thanks!
PostPosted: Wed Jan 25, 2012 2:48 pm    Post subject: Reply with quote
just found mine in the garage and its a 2-seater, so of no help to you.
PostPosted: Sun Feb 05, 2012 11:41 am    Post subject: Reply with quote
Had a look at the two frames. It appears the single seat is at a slightly different angle.If you look at the side triangle the top is 240mm the frame side is 130mm and the angle is 260 mm. Will try to get some pictures to show difference.
bimototo
PostPosted: Sun Feb 05, 2012 9:20 pm    Post subject: Reply with quote
thanks a lot, but don't worry,
I found the way to use mine frame, today i've start to move part of the wiring, include cpu and rectifire in the front (I've take out the airbox several year ago),
so stay tuned, I will post some picture Very Happy
