Sprockets.
BB1
PostPosted: Thu Nov 13, 2008 11:50 pm    Post subject: Sprockets. Reply with quote
You can get replacement Sprockets made by Talon http://www.talon-eng.co.uk/.
at about 40 each!
You can machine the standard F650 front sprocket down so it has a 3mm offset
Standard front is 17 teeth but if you go up to 18 or 19 teeth and go slightly larger on the rear to compensate you can clear the swinging arm with the chain.
Cheers,
Carl
Admin
Site Admin
PostPosted: Fri Nov 14, 2008 11:33 am    Post subject: Reply with quote
B&C supplied me with a rear sprocket for my Dieci recently. Said they would have to have it made but it turned up about 2 days after ordering it.
Keith
Anders
PostPosted: Sun May 10, 2009 12:09 am    Post subject: Re: Sprockets. Reply with quote
l
Wieres in Gremany has a reasonable selection of Bimota sprockets.
http://www.wieres.com/index.php?shsel=&warengruppe=&func=shop&search=bimota&limiter=10&option=&secure=&seite_aktuell=1
By the way, I have installed Team Pami's lower primary gearing kit and a 20t front sprocket, a very good solution to the chain / swing arm interference problem.
Anders
