New play thing is in bits!
Goto page 1, 2, 3, 4  Next
mainstone41
PostPosted: Tue Mar 27, 2012 11:32 pm    Post subject: New play thing is in bits! Reply with quote
Spent a fortune, It dont run and now i have it in bits! Bimota ownership is wonderful, yay! lol. Hope to have the my new purchase running tomorrow.. but dont hold me to it!
PostPosted: Wed Mar 28, 2012 7:56 am    Post subject: Reply with quote
Shocked
Yep, that's Bimota ownership Laughing
Good luck Wink
PostPosted: Wed Mar 28, 2012 4:04 pm    Post subject: Reply with quote
You do a lot of miles in the garage Very Happy
akito-man
PostPosted: Wed Mar 28, 2012 6:26 pm    Post subject: Reply with quote
Mayn;(, hope its sorted soon buddy!)
wot you got ?...me..well--
mainstone41
PostPosted: Wed Mar 28, 2012 7:37 pm    Post subject: Reply with quote
Carbs stripped rebuilt and balanced (not pouring fuel out number 3 carb now), perished coolant hose replaced just need a fuel tap or diaphragm to be on the road!!
PostPosted: Wed Mar 28, 2012 9:13 pm    Post subject: Reply with quote
good its not too bad........
PostPosted: Wed Mar 28, 2012 9:36 pm    Post subject: Reply with quote
Typical Bimota...........
one step forward and two steps back Laughing
You'll get there, and then it'll all be worth it Wink
mainstone41
PostPosted: Thu Mar 29, 2012 10:22 pm    Post subject: Reply with quote
Hopefully diaphragm on way soon so not long now till i can take her for a spin! I have managed to find out about a fuel tap overhaul kit, just waiting on price and availability from abroad so fingers crossed, will share with all if deal comes off!
PostPosted: Thu Mar 29, 2012 10:24 pm    Post subject: Reply with quote
Good man, order two Wink
mainstone41
PostPosted: Tue Apr 03, 2012 5:26 pm    Post subject: Reply with quote
Bike running replacement fuel tap on, sweet! Thanks to Evilchicken. But being a Bimota the cooling fan does not want to cut in so nissan sender to order tomorrow, D'oh! One day my beauty i will ride you, one day.
PostPosted: Tue Apr 03, 2012 6:08 pm    Post subject: Reply with quote
Oh the joys of Bimota ownership Laughing
PostPosted: Wed Apr 04, 2012 3:37 am    Post subject: Reply with quote
Are you sure it's the sender? Have you shorted the fan wires at the switch to see if the fan goes? The standard suzuki switch doesn't cut in til 105 deg Cand cuts out again at 100 deg C. Some more info in this thread -
http://www.bimotaforum.co.uk/viewtopic.php?t=1070&postdays=0&postorder=asc&start=0
mainstone41
PostPosted: Wed Apr 04, 2012 6:11 am    Post subject: Reply with quote
Have put a feed direct to the fan and it works i then shorted out the sender wiring and again the fan works but run the bike and it goes into the red with no go on the fan!
PostPosted: Wed Apr 04, 2012 7:25 am    Post subject: Reply with quote
Yep, mine goes into the red before it starts too. Only starts if stuck in traffic or at the lights.
PostPosted: Wed Apr 04, 2012 12:42 pm    Post subject: Reply with quote
I have the same problem, so I had the question, what's wrong. First I tested the fan sensor, and that was okay. Then the temp sensor and that was also okay. Only then there is the temperature indicator. According to this forum is usually the indicator that is not reliable. The next step was to test the indicator, so I had to find a resistor, and preferably an adjustable resistor. How this would be solved by MacGyver........Idea..... grabs my radio pulled it apart, and there it is an adjustable resistor. (The music will not be mist, almost deaf on one side). Sad Now, according to the manual I performed the tests, and the results are shown in the drawing and photographs.
Conclusion, indicator deviates.
Solution, you can accept that the needle is in the red, you know it does not hurt until the needle indicates max.
Or to place a resistance of 8 ohms between the indicator and sensor. So you shift the reading a little back.
Why 8 ohms, if the sensor measured a temp of 105 °C the resistance is approx 24 ohms. That’s approx the same temp when the fan kicks in.
The reading is now at the end of the white surface of the indicator. Will the temp go higher then you know that the fan can not handle it.
I’m now testing it and it seems to by working.
How do you smart people think about it, if I’m wrong please tell me. I can only learn from it
Smile Smile Smile
Sorry, I could not make the text shorter. Embarassed
Page 1 of 4
