Rascal
Posted: Wed May 09, 2012 12:23 pm Post subject: Wanted DB1 exhaust shroud/cowl |
Hi DB 1 enthusiasts,
Not sure if this wtb request is a repeat, lap-top had a senior moment !!!
Wanting an exhaust shroud/cover fitted to the std db1's & db1s models that mounts rear of the lower/bottom main belly-pan/ fairing item and covers the initial taper of the std exhaust system ( sr model having a 2-1 system)
Not too concerned if the item is damaged ( within repair )
The bike i bought is missing this item, & require for the "new generation db1" rebuild.
Regards
Russell _________________ Rascal |
