SB8K Santamonica - Exhaust
Falcolion
PostPosted: Sun May 13, 2012 12:47 am    Post subject: SB8K Santamonica - Exhaust Reply with quote
Has anyone installed any aftermarket slip-ons on Santamonica? I am interested to see some examples.
Also does anyone know if the front brake and clutch master cylinders are same as on DB7 or DB6 or DB5 or Ducati 1098/1198 or any other bike out there?
Thanks
Vlad
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2007 Aprilia RSVR Bol D'Or
2006 Bimota SB8K Santamonica
2005 Benelli Tornado Tre
2002 Mondial Piega
PostPosted: Mon May 21, 2012 1:40 pm    Post subject: Reply with quote
I've seen some Yoshi's on a 6R I think. If you had a pair like an crossplane R1 they'd probably look right. You'd either need to cut and shut them onto your pipework or get links made down to the headers.
I've used an aftermarket Brembo radial on my Six, the colour and levers don't match but I quite like that. If you a matching pair without spending Ducati money fit a KTM pair from their big twins.
Falcolion
PostPosted: Mon May 21, 2012 5:24 pm    Post subject: Reply with quote
Thanks for the tips. I just wanted to see the actual pics if someone made it. I know I would need custom link pipes but that should not be a problem. As for Master Cylinder question, I don't want to change them I just want to know the compatibles so that I can see if I can get diffrent levers for them
Thanks
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2002 Mondial Piega
PostPosted: Mon May 21, 2012 10:01 pm    Post subject: Reply with quote
I'd need a picture to be sure, have a look for any number on them, but if they're "standard" type then I'd say they'll be brembo goldline standard Duke stuff ... but it's a guess
akito-man
PostPosted: Tue May 22, 2012 8:19 am    Post subject: Reply with quote
Did you not see my exhaust system in pics? And ill get a piccy of my brembo front brake lever set up!
wot you got ?...me..well--
Falcolion
PostPosted: Tue May 22, 2012 5:33 pm    Post subject: Reply with quote
I didn't see pics of your exhaust. As for brake levers I am interested to find out what other bikes they compatible with
Thanks
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2002 Mondial Piega
PostPosted: Wed May 23, 2012 12:49 pm    Post subject: Reply with quote
A fellow SM owner, I am not alone Laughing
One of the bikes I looked at buying from Italy had R1 cans on it as Evil suggested , with a special link pipe. Probably the way I am going to go when I get mine on the road.
Falcolion
PostPosted: Sat May 26, 2012 7:15 am    Post subject: Reply with quote
I just saw picture of this bike earlier today. In the picture the exhaust bracket is moved all the way to the back so I am wondering if the owner fabricated a new bracket. I have also seen pictures of Santamonica Gobert Edition with Titanium Akrapovic and the mounting band is right about where the current connection is.
I just want to see more pics to make decision.
I actually looked at the following exhausts: Akrapovic, M4 (oval and hex), Two Brothers (M-2 Black Carbon) and Yoshimura.
Yoshimura has very nice TRC undertail pipes that are good looking but I think they are just a bit too short. I have measured the stock cans and they are 16 inches.
TRC undertail are only 14 inches with inlet of 2.25 inches = 57 mm
another possible option is Youshimura RS-5 - 14 inches with inlet of 2.25 inches = 57 mm
TRC Tri-Oval: One option that is actually even same length as stock (16 inches) is
M4 undertail exhaust have awesome quality and Carbon Fiber looks very rich. I had M4 Carbon on my Moto Guzzi V11 which I sold and the sound was very deep but not obnoxious
Two Brothers - I think is an awesome exhaust but a bit loud if used without Powertip. I have this exhaust on my Aprilia Falco and on my track only Triumph Daytona 600 and like them.
The length of the canister is 15 inches, inlet pipe is 2" or 50 mm which exactly what the stock pipes are.
So, what combo would you choose for your bike?
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2002 Mondial Piega
PostPosted: Sat May 26, 2012 7:20 am    Post subject: Reply with quote
I would go for the yoshi trc pipes. Being slightly shorter would clean up the back end look I think.
zombie
PostPosted: Mon May 28, 2012 12:01 am    Post subject: Reply with quote
Theres a bracket, on which the rear plate holder fits, which bolts on to each of the silencers - two large screws each side. its quite important for holding the silencers in place with the standard set up.
Probably is a way around it but you need threaded inserts in both silencers in the right place to keep things fitting in the usual way. But a couple or 3 of these around both silencers might sort things out.......
http://www.jcshi-torque.co.uk/product_tamtorque.asp
PostPosted: Mon May 28, 2012 12:54 am    Post subject: Reply with quote
If you like the look of them could you just machine a couple of extensions on the link to the mid pipes?
PostPosted: Mon May 28, 2012 1:45 pm    Post subject: Reply with quote
Will be interested in what you go for. Looked at those can's myself, its either that or have a set of custom ones made at Quill exhausts. Don't seem to be silly money and they will fit the link pipes also.
