zombie
Posted: Wed May 23, 2012 10:38 pm Post subject: SB8K MPG |
hi all,
Just checking whether anyone has SB8K MPG information. Mine is doing 27mph (its very fast riding though for long periods) and I am wondering if I need to change something, as its plenty powerful and fast just thirsty.
Whats confusing me is the SB8RS does 40 something and so does the raptor which both have the same engine.
Cheers,
Zomb |
Posted: Wed May 23, 2012 11:41 pm Post subject: |
Have you had the fueling set up on a dyno ???
After that there's a small hole in the bottom of the fuel tank bung that up and it seems to make a huge difference _________________ Don't read everything you believe |
Posted: Thu May 24, 2012 8:12 am Post subject: |
27 mph is not so fast _________________ Now - SB6R, GSX1400, KTM 990 SuperDuke
It was like that when I got here |
zombie
Posted: Thu May 24, 2012 10:07 am Post subject: |
Ha ha, I mean 27mpg.
It runs absolutely great - just seems a bit thirsty.
Just to explain a bit more I've spent hours getting it to this level of performance and reliability on the fueling, hence I don't want to start the process again unless there is a good benefit likely at the end.
Commuting 70 miles a day now so a few mpg really makes a difference at the end of the week....
All the best,
Zombie |
zombie
All the best,
Zombie |
Posted: Thu May 24, 2012 3:29 pm Post subject: |
That does seem to be excessive. If its running clean though it must be chugging in lots of air to compensate in the tune and the jets much be that much bigger to? Like you say, if its running ok it might be better to let sleeping dogs lie. It might be cheaper in the long run to buy a cheap commuter then fiddle and save piling up the miles on the bim. Unless, of course, its a twisty road _________________ Pomps
akito-man
Posted: Thu May 24, 2012 5:29 pm Post subject: |
Getting about 30-35 out of mine- spirited riding, but mine is BIGGER! _________________ wot you got ?...me..well--
zombie
Posted: Thu May 24, 2012 11:09 pm Post subject: |
30-35 is not that far off, so I will leave as-is and try some less aggressive riding. With the K, it has a kind of pumper carb emulation, but if you keep twisting open slowly its very generous with the extra fuel and responds accordingly - I will try and keep the throttle more constant and see what happens.
I think the next easiest option is to clean the filter, but its only a couple of thou since I did that.
Pompey my model #2 Gobert has shower injectors only and they spray onto the plates a lot of the time, so it tends to run a bit dirty, soots up the spark plugs given half a chance particularly in cold weather when idling alot.
The shower idea and approach was nicked by Ducati and they perfected it in the 999R, BUT for low throttle openings they use a conventional injector and cross steadily over to the shower injector when the engine is pulling air through harder. This set up is mega successful and is used in 1098 1198 and Panigale to great effect e.g. a 190BHP twin !!
From my experience when my 8K is well set up it will be a bit sooty due to when its idling with a closed throttle, but will pull cleanly from closed throttle without hesitation almost all of the time - (unless its been idling for too long). It burns off accumulated soot on a long run. If you do lots of short runs or "turn the engine over now and again" you will need to change spark plugs out alot..and they are non-recoverable! That might just my bike though. If you try and lean it out too much, the throttle pick up is hesitant and it is hard to start. Again have spent much time experimenting with this with all sorts of approaches including fooling the temperature sensors into thinking its warmer/colder etc. Overall the best and easiest way I have found of tuning richness/leaness is by simply rotating the TPS very carefully one way or another.
Anyway, it has a 130bhp smooth dyno trace and is very very torquey, smooth and speedy on the open road though ( 178KG dry) which means something must be right somewhere - getting it right everywhere has always been the difficult bit.
Cheers,
Zomb |
Posted: Thu May 24, 2012 11:31 pm Post subject: |
Ah yes of course... sounds like leave well alone then. Which means we should consider fun commuters that have low consumption, good speed , handling and comfort ... Now lets me (us) think ....
I have an unusual contender! My Cbr 900 early fireblade. Cheap to run, loads of fun, sound investment and as low as they will ever be to buy. Stacks of room in the boot, super comfy and set up properly will give a stonking ride! Go for a 92' 93 model. _________________ Pomps
Posted: Tue May 29, 2012 1:56 pm Post subject: |
Zombie.
Will let you know what my Santamonica gets. Will be on the road soon as the DVLA finally accepted my forms as OK, so just waiting a reg number.
Although on initial findings , it seems to run the same as yours, very sooty at tick over with the injectors throwing bucket loads of fuel in , nice to watch though bit of a party trick these shower injectors |
Posted: Tue May 29, 2012 4:27 pm Post subject: |
As others have said, if you are enjoying yourself then what the heck re mpg, make the most of the British Summer as thats probably it for this year. As a "yardstick" my Db2 only does 20-25mpg, never push it past 90miles on a tankful as thats about it before it runs dry and theres no reserve or low fuel light that I've ever seen come on, and it almost takes the full 4 gallons when I fill up. Right enough its not a standard 900cc twin, with its FCR41 flatslides, K&N's 944 big bore kit etc, but its addictive and the sucking and flapping of the juice going through the carbs seems to make the low mpg worth it... |
zombie
Posted: Tue May 29, 2012 11:12 pm Post subject: |
I suppose you can't have everything, Pomps idea of an early fireblade is a good one but the temptation of 2 hours of Bimota riding per day is too much for me, whatever MPG its getting!
When the winter salt hits i will see how my budget-bimota-commuter i.e X-Raptor fares on the long runs. |
Posted: Wed May 30, 2012 8:07 am Post subject: |
I'm with you there Zombie.
If I coulf get a few hours of good riding in on the Bim every day I would. |
akito-man
Posted: Wed May 30, 2012 11:54 am Post subject: |
well ive ripped my right trapezius (half of my trapezium shoulder muscle) apart from agonising pain for the first 24 hrs, ive got to rest it,and take plenty of drugzz,so no bikes for a while,no work,no driving,etc etc.bored bored bored bored bored!,might catch a plane and walk the tt course!,my bike is good on fuel, no mpg,at mo,just evap per day.sheet, just taxd the r1,and wing too! loads to do,just cant! _________________ wot you got ?...me..well--
Posted: Wed May 30, 2012 11:58 am Post subject: |
Feck
tough titties
only thing to do is get your arse to the IOM
Wish i could _________________ SB6 mk1 (project mega light, big bore)
