SiBag
Posted: Wed May 23, 2012 3:32 pm Post subject: Brake Reservoir Hose and Clips |
OK all,
On a bit of a tidy up on the SB6
Brake reservoir hoses and clips are all looking a bit old and tired. So want to replace them.
On my harris I have used stainless braided hose and anodized hose end finishers, but on the SB6 the hose length is only short. So not enough room for the end finishers etc. If I just use stainless braided hose it will fray like hell and look a bit pants.
So what hose and hose clips do you all use. And where are you getting them, had a quick scoot on tinternet and can only find jubalee type clips.
Cheers in advance. _________________ Si...
SiBag
Posted: Thu May 24, 2012 11:39 pm Post subject: |
I take it no one knowswhere I can get stainless versions of the Brembo clips.
Zink plated or Black dont exactly get me hot.
Thanks for the info.. _________________ Si...
Posted: Fri May 25, 2012 6:09 am Post subject: |
Unfortunately, stainless isn't as springy as some other metals.
Use black, blends in better  _________________ SB6 mk1 (project mega light, big bore)
Posted: Sat May 26, 2012 10:04 am Post subject: |
You don't see them, one is under the res anyway. Calm yourself with knowing these are lighter  _________________ Don't read everything you believe |
