uploading image problems
runesika
PostPosted: Sat May 26, 2012 6:37 pm    Post subject: uploading image problems Reply with quote
Hi , I have tried to post up pictures using the "upload image " on the top of the screen but after trying for a good while it comes up with "bad request "
Am i doing something wrong ?
PostPosted: Sun May 27, 2012 12:31 am    Post subject: Reply with quote
Hi and welcome to the forum. the easiest way i've found is to create a free account in photbucket or a similar site and limk the photo to here usung the Img tab above. You need to put the Img at both ends of the link.
PostPosted: Thu May 31, 2012 7:54 am    Post subject: Reply with quote
Uploading the image usually works, pictures have to jpegs,gif or tifs I think, and quite small in size ( can use MS picture manager and compress for web page ) then copy link once up loaded , press the img tab, insert link , and then *img tab ( the img tab will flick betweent the 2 ) so before you preview it will look something like this :-
[img] link here [/img]
