SB6 - Temperature Gauge
Duquois
PostPosted: Wed Jun 13, 2012 1:33 pm    Post subject: SB6 - Temperature Gauge Reply with quote
During a 60 miles ride last night the temperature gauge on my bike didn't rise above the blue part of the dial. It's the third time I've noticed this. It was quite cool last night. Are they all the same? Thanks for any advice. Andrew
SB6, Moto Guzzi Griso 8v, Guzzi 1100 Sport inj
MARTIN
PostPosted: Wed Jun 13, 2012 4:02 pm    Post subject: Reply with quote
Possible,but I would still check two things
Ensure temp gauge sensor is conected on pipework above engine
Ensure that there is coolant and it is flowing around system
be carefull,although header tank above headlights may show
full -rubber hose from expansion tank to pipework may be blocked
or restricted
Marty
(00) SB6 (95) HD FXDWG STRETCH (01)GSXR1000K1
PostPosted: Wed Jun 13, 2012 10:21 pm    Post subject: Re: SB6 - Temperature Gauge Reply with quote
They are pretty in-accurate and temperamental things but check out Marty's suggestions and make sure the cooling system is bled of air properly Wink
Duquois
PostPosted: Thu Jun 14, 2012 10:55 pm    Post subject: Reply with quote
Thanks for the advice Martin & Oily, I'll check out those points this weekend. Cheers, Andrew
PostPosted: Thu Jun 14, 2012 11:01 pm    Post subject: Reply with quote
Don't forget the bleed screw on the metal pipe that runs over the engine and also houses the temp sender Wink
