YB11 hits the dyno, with 130hp at the back wheel
PostPosted: Wed Aug 15, 2012 7:03 pm    Post subject: YB11 hits the dyno, with 130hp at the back wheel Reply with quote
I had the YB11 on the Dyno last weekend, at www.projex-uk.co.uk
It's stock, except a Two Brothers race can. The dyno guy reckoned the fueling was good all the way though, nice and crisp.
It made 130bhp at the wheel, which is about what he expected. Early carb R1s make about the same and injected later ones around 154
Clip here:-
http://www.youtube.com/watch?v=TUUrj-D5bKs&feature=youtu.be
PostPosted: Wed Aug 15, 2012 7:08 pm    Post subject: Reply with quote
Why the Dyno?
did you have a problem?
PostPosted: Wed Aug 15, 2012 7:20 pm    Post subject: Reply with quote
just curious. Greybike forum were running a dyno day at projex in Cradley Heath, £10 a run. I took the NC30 too, it made 58.5hp at the wheel, was on the rich side
PostPosted: Wed Aug 15, 2012 7:36 pm    Post subject: Reply with quote
...£10 a run...
Bargain Wink
PostPosted: Fri Aug 17, 2012 10:41 pm    Post subject: Reply with quote
AFR is all wrong as the lambda died! Also no accurate RPM as couldn't reach the HT leads with the fairing on!
PostPosted: Fri Aug 17, 2012 10:54 pm    Post subject: Reply with quote
This was after the engine was done
I was thinking of getting a base run done sometime soon.
PostPosted: Sat Aug 18, 2012 7:58 am    Post subject: Reply with quote
EC- What's that 149 at the wheel? Good result. What's done to it?
you going to the Greybike meet in Friskney tonight?
