SB6 Swingarm Bolt
Og
PostPosted: Sun Aug 26, 2012 6:31 pm    Post subject: SB6 Swingarm Bolt Reply with quote
Guys
I am missing a swingarm bolt! Sad
They look special! Sad
Any idea where I can find a replacement?
Can anyone sell me a replacement?
Any help or thoughts appreciated.
Og
Current Bikes: SB6 Crescent; SB6 (red and white); SB6 (Not red and white)
PostPosted: Sun Aug 26, 2012 7:43 pm    Post subject: Reply with quote
no douubt Oily could spare you one out of his collection (or even make you one) Cool
PostPosted: Mon Aug 27, 2012 2:18 pm    Post subject: Reply with quote
Sorry, neither Crying or Very sad
What I can do for you is take all the dimensions of the one I've just taken apart if that's any help?
Just a thought, I could price up having a Ti spindle made and then sell you my standard spindle Wink
Og
PostPosted: Mon Aug 27, 2012 5:46 pm    Post subject: Maybe the local Ducati Dealer? Reply with quote
Reading the forum it occurs to me that the Ducatis look to have a lot of familiar parts. Will have a look. Idea
Oily, I assume the spindle comes with the two bolts? Very Happy
Og
PostPosted: Mon Aug 27, 2012 6:29 pm    Post subject: Reply with quote
I have to ask......
Why do you need a spindle Question
Og
PostPosted: Tue Aug 28, 2012 8:54 am    Post subject: Reply with quote
Chinese whispers at work.
I don't need a spindle, I need a bolt (and the black plastic frame cap that used to cover it)
Could be my terminology. Question
The swing arm is fixed to the base of the frame at the pivot point via a brass coloured bolt on either side. The bolts are under the black plastic frame caps.One is missing, presumably it fell off! Previous owner issue I suspect but too long ago to go there.
When I checked, remaining bolt on the other side was loose also. I reckon my Black/Red Bimota should bark its turning out to be such a dog this summer! Ho hum, I recall the wife told me not to buy a non red white one! Just found an oil leak! I thought the strange handling was under-inflated tyres, then I found I was missing a swingarm bolt, but maybe it was just the oil p**sing onto the rear tyre! You got to love these bikes! Razz
PostPosted: Tue Aug 28, 2012 9:04 am    Post subject: Reply with quote
Not your terminology OG, it's me not reading the post properly Wink
At least you've got one bolt as a pattern. Shouldent be at all difficult for your local engineer to replicate. Hardest part would be the hexagonal recess for the allen key but you could have it with a hex head instead or many other designs.
Have you tried all the usual, European suppliers before you go to that much effort?
Keep us updated Wink
PostPosted: Tue Aug 28, 2012 1:20 pm    Post subject: Reply with quote
Or use an allen bolt.
The covers are just grommets measure the diameter and order a pair, might cost you nearly £6
http://www.ebay.co.uk/itm/2-x-Rubber-Grommet-Open-closed-20mm-25mm-32mm-38mm-50mm-/160519544814
PostPosted: Tue Aug 28, 2012 1:45 pm    Post subject: Reply with quote
Find me some 34mm blind grommets EC Wink
as for the allen bolt idea......it is a pretty complicated bolt but a m10 allen bolt and a machined washer might just do the trick Wink
...depends what level bodge your willing to accept Laughing
Nice stainless m10 socket head bolt. Stainless machined washer to suit and probably a better solution than Bimota's Wink
Now I've talked myself into that...how much are you willing to pay OG? Laughing
PostPosted: Tue Aug 28, 2012 6:36 pm    Post subject: Reply with quote
stick a 38mm in it ... 34mm is 1 3/8 inch
but
http://www.motorcyclefasteners.co.uk/Motorcycle-Frame-Plugs.html these are rigid which isn't so great cos they stick out a little at the top where the frame changes shape
If there's a demand I can get some made up.
Og
PostPosted: Tue Aug 28, 2012 7:20 pm    Post subject: Reply with quote
Oily, if you don't mind making them, I don't mind paying for them.
PM or email me a price and I will get it sorted Very Happy .
Og
Og
PostPosted: Tue Aug 28, 2012 7:23 pm    Post subject: Reply with quote
but
Should I buy the 35mm or the 38mm? Anything will be better than two holes in the frame?
Og Question Smile
PostPosted: Tue Aug 28, 2012 7:41 pm    Post subject: Reply with quote
Og wrote:
but
Og Question Smile
The hole in the Mk 1 frame is 33mm so 38 seems a bit big to me Wink
PostPosted: Tue Aug 28, 2012 7:48 pm    Post subject: Reply with quote
Og
If you can wait a couple of days, I'll knock a couple up Wink
I'm thinking i can make the washer/spacer out of aluminium and it's going to be lighter than the original which would be great for my new project Wink
