SB6 anyone?
Post new topic   Reply to topic    Bimota Forum Forum Index -> Bikes Wanted
RWG
PostPosted: Wed Oct 17, 2012 8:36 pm    Post subject: Reply with quote
Lucky enough to have had both, Sb6r wins hands down, it turned in quicker felt it was faster in turns I was familar with on both machines. Just my point , but both seriously. Good bikes.
I want one
BirgerZorro
PostPosted: Sun Dec 02, 2012 12:09 am    Post subject: Reply with quote
yepyep27 wrote:
Hey could you or someone else give me a quick run down on the differences between the SB6 and SB6R besides the obvious body work?
Yes!
The SB6 is good looking while SB6R is ugly...... Smile
Bimota KB1, SB2/80, YB6 Exup, SB8R,
Ducati 900 MHR, 900 SS, 900 SSie, 851
Moto Guzzi Le Mans
BMW K1
And seven more bikes...... Smile
Porsches 911E, 911S, Carrera 3.0, 928S, 928S4, 928GTS
PostPosted: Sun Dec 02, 2012 9:34 am    Post subject: Reply with quote
...and just to balance the previous comment (which I agree with)
The SB6 is a primitive, badly designed and badly built, rattley race bike while the 6R is better built, more powerful, better handling usable every day, and a decent alternative to a Jap bike Wink
BirgerZorro
PostPosted: Sun Dec 02, 2012 12:14 pm    Post subject: Reply with quote
They have the SAME power......... Smile
And the SAME chassi...... Smile
Moto Guzzi Le Mans
BMW K1
PostPosted: Sun Dec 02, 2012 12:19 pm    Post subject: Reply with quote
No they don't the 6R makes more power due to its air box design, and its bodywork is more aerodynamic
BirgerZorro
PostPosted: Sun Dec 02, 2012 12:32 pm    Post subject: Reply with quote
Since I have been dealing with Bimotas since 1978 I think that I know a thing or two about them. Bodywork has NOTHING to do with the chassi AND they have the same engine and they have the sam specification according to the factory.... Smile
Moto Guzzi Le Mans
BMW K1
PostPosted: Sun Dec 02, 2012 5:17 pm    Post subject: Reply with quote
By the way...welcome to the forum
oh yes, before i forget....your wrong, on both counts Laughing
BirgerZorro
PostPosted: Sun Dec 02, 2012 11:27 pm    Post subject: Reply with quote
Nope!
The ONLY difference is that the SB6R has a 10 mm longer swing arm!
Check with the factory if you like... Smile
Moto Guzzi Le Mans
BMW K1
PostPosted: Sun Dec 02, 2012 11:37 pm    Post subject: Reply with quote
Nope!
Laughing
Wrong again...
The front half of the frame is different to accommodate the ram air intake and battery tray.
All the bracing around the head stock is totally different amongst other things and they are defiantly NOT interchangeable.......
ask me how I know Wink
P.S. Don't need to check with the factory, I can check with the contents of my garage.
do you really believe everything the factory says?
PostPosted: Sun Dec 02, 2012 11:44 pm    Post subject: Reply with quote
were not talking about factory claims were talking from our experience ... well more Oily's experience. The 6R frame isn't braced around the headstock. Of course Bimota changed the wheels which slowed all their bikes down a bit but we try not to talk about it.
The 6R had ram air, which is usually worth something to most manufacturers especially when the 6 one is generally thought to be restrictive.
The 6R's swingarm isn't just longer though is it ?
sb6rdaz
PostPosted: Mon Dec 03, 2012 12:07 am    Post subject: Reply with quote
And the 6R makes more power period, due to the larger airbox, which is still too small, and which proves the SB6 airbox was a huge mistake.
Even the pukka Dynojet kit came with a drill to knock a load of holes in it.
Factory claims or not, my Dyno tells the story every time. SB6 lucky to break 130bhp, SB6R usually 135bhp, mine with 30% bigger carbon airbox 143bhp.
Daz.
It's mine and I'll wash it as fast as I like!
BirgerZorro
PostPosted: Mon Dec 03, 2012 9:39 am    Post subject: Reply with quote
Daz.
Engines do vary within a batch of engines. If you take 15 engines of the same batch the power will vary in the batch. And every now and then you get a blueprinted engine from the factory; when every tolerance match up you can get up to 10-15 % over the specification. Period! Smile
Moto Guzzi Le Mans
BMW K1
PostPosted: Mon Dec 03, 2012 9:56 am    Post subject: Reply with quote
I think we are (mostly) well aware of that fact, particularly sb6rdaz Wink
But as you were not talking about individual, blueprinted engines but ex-factory engines, I fail to see how that makes the power of the SB6 and SB6R the same?
I'm presuming, of course that you ride both SB6 and SB6r and not just reading the factory propaganda?
As an aside, I'm sure it's possible to extract huge amounts of power from these engines which the factory never bothered to do Wink
sb6rdaz
PostPosted: Mon Dec 03, 2012 9:58 am    Post subject: Reply with quote
Daz.
Correct, but I am not refering to one bike of each model, I'm looking at a number of each, and the GSXR1100 engines are VERY consistent. I have run 5 SB6R's on my current Dyno, and all made within 2bhp when tuned and set correctly with aftermarket pipes. PERIOD. The relatively low state of tune of the stock 1100 motor means it is less sensitive so less variation occurs. But back to back on the 6R with stock airbox to larger item released more power, proving the airbox is still restricting the engine, and the SB6 airbox is tiny in comparison, so even more restrictive. PERIOD AGAIN.
And you certainly do get variations of 10-15% on 130bhp+ engines, the tolerances they are built to are far better than that, 5% absolute maximum.
Daz.
PostPosted: Mon Dec 03, 2012 10:15 am    Post subject: Reply with quote
A stock SB6 you'd expect 126bhp. Given the delivery and torque thats fine.
Bimota probably took the Suzuki figures and went from there, and the Suzuki figures are optimistic.
Post new topic   Reply to topic    Bimota Forum Forum Index -> Bikes Wanted All times are GMT + 1 Hour
Page 2 of 3
