Posted: Mon Sep 24, 2012 8:41 am Post subject: Knowledge test - are you an expert bimotisti?? |
Well here is a question for you SB "experts". Do you know what glue/filler they company used to join the frame to the aluminium swinging arm hanger on the SB4??? Having taken the bike to pieces the tubes are bolted to the aluminium carrier but they have glue/filler in the joint as well. It is a grey colour and looks like hardened 3 bond or plastic padding but I guess it pre-dates either being 1984. |
bimototo
Bimsb6
Posted: Mon Sep 24, 2012 6:43 pm Post subject: |
It may be worth having a word with dave pearce of tigcraft ,he built the prototype frame for the mz scorpion that had glued together sections . |
Posted: Mon Sep 24, 2012 8:58 pm Post subject: |
Bimsb6 wrote: |
good call - or an aircraft technician _________________ Don't read everything you believe |
MARTIN
Posted: Tue Sep 25, 2012 7:46 am Post subject: |
Same glue as they use on the Benelli Tornado
"reinforced by structural gluing (as in the aeronautic industry) to completely exclude the possibility of micro-movements and vibrations. " _________________ Marty
Posted: Tue Sep 25, 2012 9:20 am Post subject: |
Thanks for the great suggestions so far - I'll let you know how it progesses |
MARTIN
Posted: Tue Sep 25, 2012 9:40 pm Post subject: |
Bit of research try
http://www.theadhesiveworld.com/epoxyadhesive.html
Grade- AW/TFIX EPOXY PR ( Two Component Epoxy Adhesive)
DESCRIPTION: AW/TFIX EPOXY PRis a two component super strong epoxy glue, bonds almost anything to anything from miniature electronic parts to hefty structural components. This multipurpose two component system comprises of Epoxy resin and Polyamide Hardner which need to be mixed well in the recommended ratio to achieve optimum results.
AW/TFIX EPOXY PRis a thermosetting system which means, that the resin and the hardner on mixing cure by polymerization to a rigid thermoset mass which on heating might soften but shall not melt and flow. This system does not include unstable matter such as solvent or water and hence there is negligible shrinkage on curing. AW/TFIX EPOXY PR which is internally flexible system, provides sturdy joints with outstanding low creep properties make it ideal for structural bonding applications. AW/TFIX EPOXY PRis an outstanding tool in Do it your self Kit.
APPLICATIONS: AW/TFIX EPOXY PRis a multipurpose structural adhesive finding extensive applications in nearly all the major industries. These applications can be found in OEM or Maintenance. This system is an essential tool for engineers and proved its value in numerous applications in:
•Automobile
•Electronics
•Electrical
•Railway
•Aeronautical
•Construction and
•Engineering industry _________________ Marty
Posted: Wed Sep 26, 2012 9:49 am Post subject: |
I know that in the aircraft structure sometimes glue / filler is used to prevent contact corrosion.
That’s normally don when two dissimilar metals are in contact. It’s because of the electro-potential voltage of the metals.
In your case I would say it’s more for prevent contact corrosion than structural strength.
If you want I can look for the best glue to use in your case. _________________ vince
Posted: Wed Sep 26, 2012 2:30 pm Post subject: |
Hi Vince
That would be great. There is a decent bit of a gap around the aluminium joint area so it isobviously a filler as well as adhesive . Ive followed up the other few leads but still waiting for that elusive response from Bimota!!! |
Posted: Wed Sep 26, 2012 3:41 pm Post subject: |
bimotanige wrote: |
Don't hold your breath _________________ Don't read everything you believe |
Posted: Mon Oct 01, 2012 5:18 pm Post subject: |
bimotanige wrote: |
Hahahahahahahahahaha...............
you just never know
If the question relates to a pre Bimcati, than as evil chuck said....don't hold your breath _________________ SB6 mk1 (project mega light, big bore)
Posted: Mon Oct 01, 2012 8:51 pm Post subject: |
Yes they are truly shocking in their support - I don't know why as I've been to the factory twice and they were great. Even tried to sell me a load of crated sb8 engines! |
