YB9 Sri
firststrike
PostPosted: Sun Oct 07, 2012 2:21 pm    Post subject: YB9 Sri Reply with quote
Hi guys, looking for a pair of mirrors and carbon air scoops for Yb9Sri. Guess this should be in parts wanted but how do you post there?
The Red Barron, Bimota YB9Sri, yamaha RD500lc, yamaha RD500 lc YZR replica, Ducati 750ss
PostPosted: Mon Oct 08, 2012 9:26 am    Post subject: Reply with quote
I think the mirrors look like the Ducati 916 but the mating surface with the fairing is flat (916 have a concave curve). If they're flat use Cagiva Mito / Sachs XTC ones.
http://www.ebay.co.uk/itm/SACHS-XTC125-MIRRORS-PAIR-BLACK-SUPERB-QUALITY-E-MARKED-CAGIVA-/221056425224?pt=UK_Motorcycle_Parts&hash=item3377fd5d08
Air scoops are going to be harder but they're simple cylinders I think .... try PJ Engineering - they do exhaust can skins and stock a lot of carbon cylinders for that.
PostPosted: Mon Oct 08, 2012 11:09 pm    Post subject: Reply with quote
drop Jack a line:
'Jack Blacoe: for replacement fairings & carbon frame protectors. Now taking orders soon for the following, sb6, sb6r, sb8r & kb1fairings. Also sb6, sb6r & sb8r petrol tanks in carbon. Also YB9 Carbon air tubes. Coming soon heel protectors. Jack.blacoe@btinternet.com'
it's an old lead from the Bim enthusiasts club, don't know if Jack is still making bits
good luck
Ian
http://thecrankcase.com
firststrike
PostPosted: Wed Oct 10, 2012 11:09 pm    Post subject: Reply with quote
Thanks for the reply, was looking at Ducati mirrors but the Sachs look identical. The air scoops are the ones on the outside of the fairing which are moulded carbon fibre and not the straight tubes, but many thanks anyway. Regards Dave
firststrike
PostPosted: Wed Oct 10, 2012 11:11 pm    Post subject: Reply with quote
crankcase wrote:
drop Jack a line:
good luck
Ian
Thanks for the reply Ian. Regards Dave
PostPosted: Thu Oct 11, 2012 7:48 am    Post subject: Reply with quote
I tried Jack a couple of years ago hence me having carbon parts made elsewhere Wink
Do you have the old ones to use as patterns?
PostPosted: Wed Oct 24, 2012 8:47 am    Post subject: Reply with quote
found an intake scoop:
http://www.google.de/imgres?start=154&um=1&hl=de&biw=1366&bih=598&tbm=isch&tbnid=6IN2Yh-YALSAzM:&imgrefurl=http://www.bimotagalleria.nl/index.php/motorparts/bimota-yb/yb6.html&docid=m76p8Cn6rhi0rM&imgurl=http://www.bimotagalleria.nl/media/catalog/product/cache/1/small_image/205x/9df78eab33525d08d6e5fb8d27136e95/0/3/038_voor_wielas_bimota_yb4-6-8_75_.jpg&w=205&h=205&ei=05qHUNriCo_OswbDk4DgBA&zoom=1&iact=hc&vpx=1059&vpy=58&dur=5541&hovh=164&hovw=164&tx=127&ty=124&sig=109668631154148423609&page=7&tbnh=142&tbnw=142&ndsp=31&ved=1t:429,r:75,s:100,i:229
then click on 'motorparts' it's the 6th part down
might have to call, because they don't list any prices.
good luck
Ian
firststrike
PostPosted: Wed Oct 24, 2012 6:29 pm    Post subject: Reply with quote
Thanks crankcase, the item shown on the website is the very part i am looking for, i still have the other side. I have mailed them for prices. Regards Dave
Mike Jennings
PostPosted: Fri Oct 26, 2012 3:51 pm    Post subject: Reply with quote
Hello firststrike,
if you don't find any let me know as I might have a pair somewhere,
Cheers, MikeJ
firststrike
PostPosted: Fri Oct 26, 2012 4:28 pm    Post subject: Air scoops Reply with quote
Hi Mike, thanks for the message. I have tried a couple of places but have had no luck whatsoever, the one website called Bimota Galleria in Holland showed the very one that i require in the pictures i.e. l/h but i have been unable to contact them by any means. If you have a pair i would be quite happy to purchase them from you, they are the moulded parts that sit outside of the fairing and the mirror passes through them. Strange tale regarding this particular Bimota, I bought it new in 2000 but it was missing various parts the l/h air scoop and mirror, rear light assembly, gear change linkage rod plus a few other bits and bobs oh and it was a non runner, that turned out to be the data tool immobiliser. All was reflected in the price though. Regards Dave
Mike Jennings
PostPosted: Sat Oct 27, 2012 11:08 am    Post subject: Scoops Reply with quote
Hello Redbarron,
I've found the scoops and have sent you a couple of p.m.s,
Cheers, MikeJ
PostPosted: Tue May 14, 2013 7:21 am    Post subject: Reply with quote
just in case
these have just turned up:
http://www.ebay.de/itm/BIMOTA-YB9SRI-CARBON-LUFTEINLASS-CARBON-VERKLEIDUNG-YB9-NEU-TOP-CARBON-YB-/130907291905?pt=Motorrad_Kraftradteile&hash=item1e7aaec101
