Posted: Sun Oct 28, 2012 10:05 am Post subject: |
It makes some sense bud, but I think staying with 180's for a quicker turn in and stable mid corner speed is worth the extra weight. Better to wait for some good light wheels the correct size to turn up. We could meet up to have a look at your current settings in the mean time. I oftne head up to Oilys and he's not far from you? _________________ Pomps
SiBag
Posted: Sun Oct 28, 2012 11:22 am Post subject: |
Pompey wrote: |
It makes some sense bud, but I think staying with 180's for a quicker turn in and stable mid corner speed is worth the extra weight. Better to wait for some good light wheels the correct size to turn up. We could meet up to have a look at your current settings in the mean time. I oftne head up to Oilys and he's not far from you? |
Ye could be useful.
Its some where close but it can still be a bit of a calsaterian italian bitch and trie to kill me now and then, (Or am I just a big girl)
Tends to wobble and wollow a bit in bumpy sweepers, which scares the poop out of me. Turn in is good. I was supprised by dropping the bars 15mm or so how much quicker it turns in. I presume cos its now got a little more of my weight on them. _________________ Si...
Posted: Sun Oct 28, 2012 3:42 pm Post subject: |
15mm is a lot. Ir not only allows more weight further forward but more importantly it changes to a steeper rake for the forks which in turn shortens the wheelbase. All 3 will help turn in does compromise stability ... _________________ Pomps
Posted: Sun Oct 28, 2012 7:21 pm Post subject: |
Dropping the bars doesn't change the geometry it's dropping the forks through the yokes that will do that
I dropped the bars
Posted: Mon Oct 29, 2012 9:50 am Post subject: |
Ahh I assumed Si meant he had dropped thru the yokes. Dropping the bars should do nothing. It can make the ride position more suitable for the rider but if you are riding without the weight thru your wrists and with a relaxed grip and flex in your elbows as you should be then it makes no difference to weight transfer either...
of all the bikes I have owned the sb6 is the one that needs most attention and the best rewards for correct set up. _________________ Pomps
Posted: Mon Oct 29, 2012 10:12 am Post subject: |
...Si....
You could always buy my brand fire new, UP7 dymags off me, they'll slot straight in _________________ SB6 mk1 (project mega light, big bore)
Posted: Mon Oct 29, 2012 2:30 pm Post subject: |
I find it a bit more comfortable and you're closer to the tank which puts you a bit more under the windscreen. _________________ Don't read everything you believe |
SiBag
Posted: Mon Oct 29, 2012 8:25 pm Post subject: |
Dont forget that by changing the riders position you will change the weight distrabution and there for the handling.
I know its sound like twadle, but it has made a differance, plus my writs are a little more comftable
And yes Oily Id love your dymags, but I dont think I could afford one of those at the moment. _________________ Si...
Posted: Mon Oct 29, 2012 11:21 pm Post subject: |
SiBag wrote: |
I know its sound like twadle, but it has made a differance, plus my writs are a little more comftable |
The difference in weight distribution is negligible you don't sit any forward youre just lower down. _________________ Don't read everything you believe |
Posted: Tue Oct 30, 2012 9:56 am Post subject: |
Correct. Distribution front and back is nil. At best you lower the center of gravity slightly when it doesnt matter on the straights. Moving body position thru the corners to lower center of gravity would / should happen no matter where the bars are. _________________ Pomps
CBar
Posted: Tue Oct 30, 2012 10:07 pm Post subject: |
[quote="SiBag"]
Pompey wrote: |
Tends to wobble and wollow a bit in bumpy sweepers, which scares the poop out of me. Turn in is good. I was supprised by dropping the bars 15mm or so how much quicker it turns in. I presume cos its now got a little more of my weight on them. |
Mid-turn chatter under neutral throttle is caused by improper front/rear bias. Adjust ride height. |
SiBag
Posted: Wed Oct 31, 2012 11:21 am Post subject: |
[quote="CBar"]
SiBag wrote: |
Pompey wrote: |
Which way, back end lower of higher? Havent checked what the rake angle is set to either.
I would not have described it as chatter though ? ? _________________ Si...
Mike Jennings
Posted: Wed Oct 31, 2012 5:55 pm Post subject: SB6 wobble |
Hello Sibag,
silly question I know, but have you tried adjusting the steering damper? (Presuming you've taken half the bodywork off to reach it )
Cheers, MikeJ |
Posted: Wed Oct 31, 2012 9:13 pm Post subject: |
I took the steering damper off _________________ Don't read everything you believe |
Posted: Wed Oct 31, 2012 9:21 pm Post subject: |
...Dangerous things steering dampers.....
Usually there to mask handling faults
I'm not sure if any of my bikes still has a steering damper but I do have a big box full of them if any one needs one _________________ SB6 mk1 (project mega light, big bore)
