SB6 Rear wheel fitment
Goto page Previous  1, 2, 3
SiBag
PostPosted: Thu Nov 01, 2012 10:35 am    Post subject: Reply with quote
I have the damper set on about 2 or 3 clicks from fully off.
It does shake its head a little if you clip a cats eye hard on the gas.
Si...
PostPosted: Thu Nov 01, 2012 2:08 pm    Post subject: Reply with quote
Get the suspension set up - it shouldn't shake it's head
PostPosted: Thu Nov 01, 2012 2:51 pm    Post subject: Reply with quote
...I shake my head when i disagree....
Think your bikes disagreeing with you Wink
CBar
PostPosted: Thu Nov 01, 2012 8:26 pm    Post subject: Reply with quote
SiBag wrote:
Which way, back end lower of higher? Havent checked what the rake angle is set to either.
I would not have described it as chatter though ? ?
Without knowing what you've done, I'm going to guess you need to increase the height in the front for stability. If it only gets upset in bumps, then a steering damper might help with the current setup.
Entering a turn:
If your bike doesn't want to turn-in, you can try reducing the fork pre-load. If sag is correctly set, try reducing compression damping. Tire profile will also make a difference.
Mid Turn:
If bike "wobbles" under trail braking, add rebound damping to the forks.
If bike wobbles with neutral throttle, raise front height / lower rear. You need less weight on the front.
Exiting a turn:
If the wallow is on the exit and :
-will hold line, add rebound to rear shock
-it turns well, lower rear ride height
-if bike runs wide, raise rear ride height
Confused yet?
PostPosted: Thu Nov 01, 2012 8:56 pm    Post subject: Reply with quote
Check the tyre pressures first.
Page 3 of 3
