Db7 dash?
zokdb7
PostPosted: Sun Nov 11, 2012 9:18 am    Post subject: Db7 dash? Reply with quote
Hi all,
Can anyone tell me if you changed your dash would the kph Still be the same as before? Or is the ecu that holds that info?
djt77
PostPosted: Mon Nov 12, 2012 12:36 am    Post subject: Reply with quote
Km reading will change with the unit its not linked to the ECU, so put a new dash on and will start will zero km.
zokdb7
PostPosted: Mon Nov 12, 2012 10:57 am    Post subject: Reply with quote
So is there a way of checking the k's at all?
To see if dash is original?
djt77
PostPosted: Mon Nov 12, 2012 12:52 pm    Post subject: Reply with quote
Not that I'm aware of, thought all bikes were the same?
zokdb7
PostPosted: Mon Nov 12, 2012 11:24 pm    Post subject: Reply with quote
Same but I thought spending gazillion dollars on a bike it would somehow tell you? Anyway thanks mate
