Posted: Sat Nov 17, 2012 10:58 am Post subject: Winter maintenance… |
Now its time to do my winter maintenance and I am thinking of a complete dismantling of the bike. If someone has ideas of tips and tricks for some modifications please let me now.
What do you guys think of a lithium battery in the SB6
Now days the lithium battery is powerful enough and in size small enough to just install one battery. _________________ vince
Posted: Sat Nov 17, 2012 11:27 am Post subject: |
Winters not here yet Vince
Best tip........fit a turbo
Just bought a lithium battery but haven't fitted it yet...watch this space _________________ SB6 mk1 (project mega light, big bore)
Posted: Sat Nov 17, 2012 12:03 pm Post subject: |
oily wrote: |
Just bought a lithium battery but haven't fitted it yet...watch this space |
If the temperature drops beneath 6 ° C it’s wintertime…
There is no place to install a turbo
What brand is the battery _________________ vince
Posted: Sat Nov 17, 2012 12:33 pm Post subject: |
...Yeah but the temperatures still above six here
how about a very small turbo?
The battery is a Shorai _________________ SB6 mk1 (project mega light, big bore)
Posted: Sat Nov 17, 2012 12:46 pm Post subject: |
oily wrote: |
Hmmm,…..maybe an idée..
Did you do already some research….you have some information for me..
Posted: Sat Nov 17, 2012 8:30 pm Post subject: |
How about a big bore kit ? _________________ Don't read everything you believe |
sb6rdaz
Posted: Sun Nov 18, 2012 12:21 am Post subject: |
I've run my 6R on a Lithium, and downsized it to YTX9 equivalent, is excellent. Cranks the bike better, is smaller, and weighs f**k all.
Have run them on the GSXR SRAD race bikes too, even on total loss they do fine. Real funny when they do run flat, they drop off almost like hitting the kill-switch!
Daz _________________ It's mine and I'll wash it as fast as I like! |
Posted: Sun Nov 18, 2012 9:22 am Post subject: |
Does anyone have a solution for this?
The shaft and the bushing are totally worn-out….
That's not strange when using soft materials for this construction….
What were they thinking when they designed this…
It is definitely not made for durability ..[/img] _________________ vince
Posted: Sun Nov 18, 2012 9:26 am Post subject: |
Evilchicken0 wrote: |
How about a big bore kit ? |
Definitely a point to consider ..... but not this year.
My goal now is to make the Bim more reliable
Easier to maintain.. and to overlook some strange construction designs.. _________________ vince
Posted: Sun Nov 18, 2012 9:37 am Post subject: |
Vince186 wrote: |
It is definitely not made for durability ..[/img] |
Hmmm......
Very common problem I'm afraid.
Several ways to tackle it.
Easiest is to make a complete new sleeve which I've successfully done in the past along with stainless nuts as the aluminium nuts just split when you tighten them. I also skimmed the footpeg in the lathe to clean up the wear.
I thought of having a batch made but every case has a different amount of wear and a lathe is required for the final fitting so that's out as not everyone has a lathe to finish the job.
Terrible design and a terrible choice of materials.
It requires a harder sleeve shrunk onto the footpeg and a bronze sleeve complete (perhaps) _________________ SB6 mk1 (project mega light, big bore)
Posted: Sun Nov 18, 2012 10:11 am Post subject: |
loads of space for a turbo : )
this is a 6R though . .
about the pedal bushes Vince- there are new ones available, but they will not be any better though- maybe possible to fit a grease nipple underneath.
http://thecrankcase.com |
Posted: Sun Nov 18, 2012 10:13 am Post subject: |
oily wrote: |
It requires a harder sleeve shrunk onto the footpeg and a bronze sleeve complete (perhaps) |
That’s a good solution… why don’t you make a few for us forum users.
I was thinking to make a Teflon layer between it.
Advantages is that it does not require lubrication so dirt can’t become an abrasive pastes.
I have no lathe ... but I do have the ability to use a lathe at work (an old lathe) _________________ vince
Posted: Sun Nov 18, 2012 10:19 am Post subject: |
Oeehhh....... sexy pictures Ian .. _________________ vince
Posted: Sun Nov 18, 2012 10:23 am Post subject: |
...Very sexy.....
The ultimate, a turbo Bimota
Even on a 6R, with loads more room than a 6, they can't find room for niceties such as ........ headlights and things _________________ SB6 mk1 (project mega light, big bore)
