bimotacarbon
Posted: Sun Nov 18, 2012 4:14 pm Post subject: Exhaust measurements sb6 6R |
Hi there,
I have a small question and hopefully someone has a minute spare.
My bike is currently at the bike store for the winter so i am not able to see her anymore untill march.
the exhaust which is under the 6R is more than perfect except one thing and that is that it is not made from carbon fiber.
Now i know there are some carbon fiber sleeves which you can apply on your current muffler.
I have one issue and that is i do not know the sizes of the cans.
Now i am wondering if someone from the forum wants to measure his can of the sb6 and place this on the forum so i can find the right one this winter.
Looking forward to any input.
Regards johan _________________ Ducati 750 SS café racer, BMW R nine T Cafe Racer, Husqvarna Vitpilen, KTM Rc8, Husqvarna Vitpilen 701, Bimota DB6 |
Posted: Sun Nov 18, 2012 4:38 pm Post subject: |
I've thought of doing that myself. I'll measure the cans, if I get time, later _________________ SB6 mk1 (project mega light, big bore)
Posted: Sun Nov 18, 2012 5:02 pm Post subject: |
The O.D of the sleeve is...100mm
the total length of the sleeve is...395mm
Let me know when you've found the right stuff Johan _________________ SB6 mk1 (project mega light, big bore)
Posted: Sun Nov 18, 2012 5:31 pm Post subject: |
is that for a 6 or 6R, are they indeed the same?? |
Posted: Sun Nov 18, 2012 5:35 pm Post subject: |
...Sorry....those dimensions are for the standard 6R cans:wink:
The SB6 are NOT the same, they have a taper halfway down. I'm looking into having carbon sleeves made for the SB6 if there is a demand...??? _________________ SB6 mk1 (project mega light, big bore)
bimotacarbon
Posted: Sun Nov 18, 2012 7:43 pm Post subject: |
Thanx for the input, because you have all the 6's in your barn.
Do you also know the sizes of the sb6 mufflers ( if i am right informed my 6R has sb6 mufflers instead of the bigger 6R types).
If i found the right ones i will add the link on this topic so any interested one can copy-paste it _________________ Ducati 750 SS café racer, BMW R nine T Cafe Racer, Husqvarna Vitpilen, KTM Rc8, Husqvarna Vitpilen 701, Bimota DB6 |
Posted: Sun Nov 18, 2012 7:57 pm Post subject: |
Yours have certainly got NON-Bimota end-caps.
6 and 6R are totally different and very easy to tell apart....
6R has a parallel tube type silencer where a SB6 silencer tapers down to a smaller diameter for the last third or so of the length
This is why I may look into having carbon sleeves made for the SB6 as they won't be on the shelf any where I suspect _________________ SB6 mk1 (project mega light, big bore)
Posted: Sun Nov 18, 2012 11:32 pm Post subject: |
I think the 6 has "spun" aluminum sleeves _________________ Don't read everything you believe |
Posted: Sun Nov 18, 2012 11:54 pm Post subject: |
...Just double checked.....All mine are stationary _________________ SB6 mk1 (project mega light, big bore)
Posted: Mon Nov 19, 2012 10:25 am Post subject: |
oily wrote: |
The SB6 are NOT the same, they have a taper halfway down. I'm looking into having carbon sleeves made for the SB6 if there is a demand...??? |
One set for me please _________________ vince
Posted: Mon Nov 19, 2012 11:00 am Post subject: |
...And just so there's no confusion........
...SB6 cans...
...SB6R cans...
but we all knew that anyway
bimotacarbon
Posted: Sun Nov 25, 2012 2:24 am Post subject: Ok |
I think i just have 6R silencers with modified end caps. Or does anyone have a different opinion?
bimotacarbon
Posted: Sun Nov 25, 2012 2:26 am Post subject: Ok |
Posted: Sun Nov 25, 2012 3:01 am Post subject: |
I think you have SB6 pipes with 6R sleeves, maybe not even that but straight sleeves and made up tail pipes. Bim tail pipes are rolled on the end _________________ Don't read everything you believe |
Posted: Sun Nov 25, 2012 8:58 am Post subject: |
They look to short for bim items and have had the end caps extended to clear the tail. If they work well with the engine I think they look fine. _________________ Pomps
