flarkster
Joined: 06 May 2009 Posts: 15 Location: north yorkshire
Posted: Wed May 06, 2009 6:17 pm Post subject: new member |
Hello All
I am a new member so please make allowances for my duff typing etc. I have a 1995 SB6 which has now done a biblical 1,600 miles from new. It is black and red and is totally standard and as new. has any one any info on the rear brake light switch or a possible replacement?? |
Admin Site Admin
Posted: Thu May 07, 2009 1:44 am Post subject: Re: new member |
Not sure but isn't it a pressure switch banjo bolt? If so then it is probably the same as that used on Aprilia RS125s (amoung others) and should be pretty easy to source.
Keith |
sapila racing
Posted: Thu May 07, 2009 11:26 am Post subject: |
Hi and welcome,
I also have an SB6 same colours as yours.
The original switch is useless and almost all of them fail. I replaced it with a brembo switch normally used on Ducatis.
It has the same thread etc but half the size and it doesn't fail. |
