Bmvin
Posted: Tue Nov 20, 2012 12:24 am Post subject: Fairing Fit SB6 |
Would anyone have some detailed photos of cable and wiring runs before the fairing is mounted.
I have always struggled to fit the fairing due to the wiring running under the battery box. looking at the headlights not being very bright thread the wiring run is nothing like mine with the wires to the ignition module for instance pointing to the back with mine to the front etc.
Just had the fairing painted matt black and fighting the good fight where fitting it is concerned may be due to the poor cable runs.
Many Thanks.
Vince |
Posted: Tue Nov 20, 2012 8:59 am Post subject: |
Oh cock......I was going to paint the project SB6 matt black
so it would be unique
..Tell you what, I've got an original SB6 with the fairing off at the moment. All the cable runs will be as it left the factory. I'll post some pics if you'll post some pics of your cable runs
..Definitely need pictures of the painted fairing _________________ SB6 mk1 (project mega light, big bore)
Posted: Tue Nov 20, 2012 10:02 am Post subject: |
...Here you go Vince...
...Speedo's off at the moment but you can just make out the Shorai battery which looks lost...
...that's how the CDI should be ...
...'tother side...
hope those help, shout if you need more as the fairing will be going back on soon
...Now, pictures of your fairing _________________ SB6 mk1 (project mega light, big bore)
Posted: Tue Nov 20, 2012 2:43 pm Post subject: |
I went through my wiring and tried to get it as tight as possible when I changed the front subframe - The main live is intersting Mine goes inside the forks, and my block connectors are different (cheaper) _________________ Don't read everything you believe |
Posted: Tue Nov 20, 2012 2:51 pm Post subject: |
Evilchicken0 wrote: |
I went through my wiring and tried to get it as tight as possible when I changed the front subframe - The main live is intersting Mine goes inside the forks, and my block connectors are different (cheaper) |
..Don't have it tight...or it will cut out on you chuck _________________ SB6 mk1 (project mega light, big bore)
Bmvin
Posted: Tue Nov 20, 2012 6:09 pm Post subject: |
The wiring on mine comes out under the bottom yoke and between the fork legs so clearly not correct seems to have different block connectors also.
Attached phots of work to date but suspect rear body panel will be to remove along with the fuel tank to see where all my missing length is - will ask the wife she may know!
Cheers.
Vince
upload pics
upload
free photo hosting |
Posted: Tue Nov 20, 2012 6:28 pm Post subject: |
The main loom on the near side of the bikes goes on the outside of the forks, it gets coverred by the fairing once that's on.
It comes out above the radiator
I think you'll find if you move the whole of the loom further forward it will sit right. very liitle of it is in the engine bay, you should find there's a lot of slack in your ancillaries ... well that's what your missis says
Posted: Tue Nov 20, 2012 6:52 pm Post subject: |
I am sooo loving that matt black paintwork Vince
Pretty sure my project is going to be matt black too...very stelth _________________ SB6 mk1 (project mega light, big bore)
Posted: Mon Dec 10, 2012 7:44 pm Post subject: |
...Do you have any pictures of the front fairing Vince?
Are you planning any graphics? _________________ SB6 mk1 (project mega light, big bore)
