Hursty
Posted: Wed Dec 19, 2012 9:41 am Post subject: Suzuki superbike naked |
While visiting my beloved SB6 at my mechanics this turned up
It is the NZ super bike champs GSX R1000 after he was taken out by a back marker while going for the win
It should be an easy fix for my guy, the 8 time NZ champs broken collarbone will take longer.
The data logger says it was at 260ks before braking for the last corner
My mechanic / Racer is now only 1 point off second place in the champs and had built this bike up so my Bimota is in good hands  _________________ Hursty from kiwi land  |
Posted: Wed Dec 19, 2012 10:03 am Post subject: |
...Considering it's been down the road....not too much damage, should polish out
Makes a SB6 look fairly primitive  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Dec 19, 2012 10:23 am Post subject: |
You should have robbed a few bits off it  _________________ Don't read everything you believe |
Posted: Wed Dec 19, 2012 10:24 am Post subject: |
Evilchicken0 wrote: |
You should have robbed a few bits off it  |
Definitely the British way of doing things
The modern age.....Just rob everything  _________________ SB6 mk1 (project mega light, big bore)
