SB6-R Parts
sb6rdaz
PostPosted: Wed Dec 12, 2012 8:29 pm    Post subject: SB6-R Parts Reply with quote
Hia Guys. Looking for a couple of bits for a late SB6-R if anyone has any.
Firstly need a radiator, which is originally from a Yamaha YZF1000 Thunderace. Don't need the fans or such, just a bare rad but will take whatever comes my way.
And secondly I need a gearpedal. The linkage arm etc is all good, just the pedal itself. Not tried to straighten it yet but the toe peg is worn away too so if anyone has a good one I'd prefer to replace it.
Thanks in advance for any help given,
Daz.
It's mine and I'll wash it as fast as I like!
PostPosted: Wed Dec 12, 2012 8:40 pm    Post subject: Reply with quote
...I'll check the big box of Bimota bits in the morning Wink
PostPosted: Wed Dec 12, 2012 8:43 pm    Post subject: Reply with quote
The gear shifts are different between the 6R and the 6, don't know if they're interchangable
PostPosted: Wed Dec 12, 2012 8:49 pm    Post subject: Reply with quote
No they are not Boris and yes they are Boris Laughing
The lever itself is in two parts with the cranked bit being a seperate part to the lever Wink
Check the parts list Wink
sb6rdaz
PostPosted: Wed Dec 12, 2012 8:51 pm    Post subject: Reply with quote
I'd guess it would only be the position of the roll pin groove, to position the arm relative to the pedal, think all the levers are made from the same casting. That can always be modified to suit as long as the lever itself is good.
Cheers though, didn't know they were different,
Daz.
PostPosted: Wed Dec 12, 2012 9:02 pm    Post subject: Reply with quote
gear change rod on 6r runs through the hanger on the 6 it runs behind. the coupling on the 6 is cranked.
Yes, all the levers are the same Wink
sb6rdaz
PostPosted: Wed Dec 12, 2012 9:05 pm    Post subject: Reply with quote
Well put mate, got the coupling arm, that's fine, is just the lever/pedal/whateveritisinItalian that is bent and worn. Will flip the gearchange anyway to run 1 up 4 down.
Daz.
Mike Jennings
PostPosted: Wed Dec 12, 2012 9:40 pm    Post subject: Bimota brake pedal Reply with quote
Hello,
if you search Bimota Schalt-und Fussbremshebel on ebay, there's one for sale buy- it- now from 135laura for £55.70+12.03 postage Listing no;4002500116032. If it doesn't work on ebay, try ebay.de
Cheers, MikeJ
PostPosted: Wed Dec 12, 2012 9:43 pm    Post subject: Reply with quote
Wink
http://www.ebay.de/sch/i.html?_nkw=Bimota+Schalt-und+Fussbremshebel&_sacat=0&_odkw=bimota&_sop=10&_osacat=0&_from=R40
Cool
PostPosted: Thu Dec 13, 2012 11:06 am    Post subject: Reply with quote
Sorry Daz.....
Knew I had one somewhere but when I found it....
...I remembered some chimp had already been messing with it Crying or Very sad
Why they needed to weld the two parts together I have no idea Rolling Eyes
sb6rdaz
PostPosted: Thu Dec 13, 2012 4:30 pm    Post subject: Reply with quote
Cheers for looking, fella much appreciated.
I'll have one from Germany after Christmas.
Thanks too Mike for the Ebay listing.
Daz.
