Abo-jan
Joined: 13 Feb 2013 Posts: 7 Location: Moscow, Russia
Posted: Thu Feb 14, 2013 11:11 am Post subject: Need DB6 Clutch Pressure Plate. |
Original. It is different from what is sold. The attachment of springs made much deeper. |
Abo-jan
Posted: Fri Feb 22, 2013 11:14 am Post subject: |
Needed here such as red.
waggy
Posted: Fri Feb 22, 2013 6:36 pm Post subject: |
Ok, your red pressure plate is for slipper clutches only and your silver pressure plate is for standard dlutches (All slipper pressure plates have a smooth inner face and standard have the notched ring, if that makes sense). I take it the red one is what came with your DB6, if so what you need is a slipper clutch pressure plate and there is many aftermarket items available in all colours. Hope that helps. |
Abo-jan
Posted: Mon Feb 25, 2013 6:39 am Post subject: |
Thank you. I think I found the manufacturer!)
This Bucci!) |
