Posted: Wed Feb 20, 2013 6:51 pm Post subject: Bimota Filler Cap rubber seals |
Hi all, just a quick heads up for anyone that may wish to renew the rubber seal on the petrol caps as illustrated below. Mine on the Db1 is well past its expiry date, butchered slightly and hard and not sealing properly and whilst we all may put new tyres, new seals in calipers, brake hoses etc maybe not so many choose to check their petrol cap except when filling up and lets face it we're more interested in riding at that time..
I know these caps were used on early Sb6's, Db1's and YB9's but my knowledge and library of filler caps is not perhaps what it could be (and why would it be so??)
I've failed to find exisiting "stock" but have found a UK company that will make up the seals in BA standard Nitrile rubber 5mm thick (resistant to fuel) 83mm o/d and 58mm i/d (the 85mm o/d in the picture is the alloy plate it sits on and the seal only goes to the inside of the chamfered edge.
Anyone interested in any? Early indications are around 5GBP each plus posting wherever, but this is low as it fits inside a small envelope.
The company can tool up to make a batch and bring the cost down but this runs to almost 100 needed prior to it being economically efficient.
Also linked to this post Mr Vort, as we try to chip in together on same goods to make it wohwhile ordering
http://www.bimotaforum.co.uk/viewtopic.php?p=21697#21697
Posted: Thu Feb 21, 2013 9:04 pm Post subject: Bimota Filler Cap Rubber Seals |
Any idea if these would fit a 6R hinged filler cap. A nod and a wink to Oily, who boasts both machines in his extenxive collection _________________ What, Jonny's gone! |
Posted: Thu Feb 21, 2013 9:11 pm Post subject: |
Hi Johnny, as you hint, perhaps Oiley could help, but normally the hinged caps have a much smaller aperture on the actual tank and the rubber is pressed onto the top, dimensions are on there though so throw a ruler over it to check |
Posted: Thu Feb 21, 2013 9:32 pm Post subject: Re: Bimota Filler Cap Rubber Seals |
Jonny B Bad wrote: |
Any idea if these would fit a 6R hinged filler cap. A nod and a wink to Oily, who boasts both machines in his extenxive collection |
No, They won't fit a 6R JBB _________________ SB6 mk1 (project mega light, big bore)
Posted: Thu Feb 21, 2013 11:44 pm Post subject: Bimota Filler Cap Seals |
Thanks for looking Oily.
Would be useful to know which firm has been identified to knock these up for future reference. _________________ What, Jonny's gone! |
phil-short
Joined: 30 Jul 2012 Posts: 197 Location: Dublin,Ireland
Posted: Fri Mar 29, 2013 12:11 pm Post subject: |
Has an order for these been placed cos if so I would like to put my name down for one? |
