Paioli fork preload-adjusters RSU46
PostPosted: Sat Feb 23, 2013 1:43 pm    Post subject: Paioli fork preload-adjusters RSU46 Reply with quote
It’s possible to install zx9r preload-adjusters in the Paioli. Smile
The only thing you have to do is make some changes to the zx9r preload adjusters
And as well exchange the Paioli spring with the zx9r spring with its spacers (see pics).
A how to will follow (when I have a little more time). Wink
The pre-settings of the suspension ……..That’s what I have to find out when the Bim is finished. Question
If you have the intension to do this modification, find yourself a pair of crashed zx9r forks.
Then you have all the parts you need..... probably for a very reasonable prize. Wink
vince
SiBag
PostPosted: Sat Feb 23, 2013 3:16 pm    Post subject: Reply with quote
Interesting idea.
Got me thinking, Would preload adjesters off other 46mm forks fit.
I think some of the ZXR600 had 46mm forks. Also the SV1000 and the GSXR600 share the same 46mm forks.
Hmmmmmmmm... Question
Si...
PostPosted: Sat Feb 23, 2013 4:39 pm    Post subject: Reply with quote
...Well done Vince, I'm still struggling with the re-bound adjuster. Laughing
This should also be possible keeping the Paioli spring Wink
PostPosted: Sat Feb 23, 2013 4:50 pm    Post subject: Reply with quote
The ZX9 spring should be lighter though
SiBag
PostPosted: Sat Feb 23, 2013 4:54 pm    Post subject: Reply with quote
Go on then,
Who has just had the fork tops of eBlag for a tener ?
Si...
PostPosted: Sat Feb 23, 2013 8:31 pm    Post subject: Reply with quote
SiBag wrote:
Interesting idea.
I do not know.... I would say... try... the more alternatives the better. Wink
vince
PostPosted: Sat Feb 23, 2013 8:33 pm    Post subject: Reply with quote
Yes it is……1,2kg lighter total on both forks. Rolling Eyes
The zx9r spring feels harder to compress.
vince
PostPosted: Sat Feb 23, 2013 8:35 pm    Post subject: Reply with quote
I am very curious what you have invented…. Wink
vince
PostPosted: Sun Feb 24, 2013 12:20 am    Post subject: Reply with quote
That figures - if you say the bikes have a conprable wiegth then the XR9 springs have less material and a steeper angle on the windings.
PostPosted: Sun Feb 24, 2013 9:43 am    Post subject: Reply with quote
The ZX9R is roughly 7kg lighter than the SB6 Shocked
We don't know where those extra 7kg's are situated but it's a fair bet some of it will be on the front end so a lithium battery and carbon wheels should take care of that.......
So maybe the ZX9 fork springs are the way to go....if they can be set up and made to work Wink
CBar
PostPosted: Sat Mar 02, 2013 2:53 am    Post subject: Reply with quote
The stock ZX-9R spring rate should be lighter (softer) than the stock SB6 rate.
PostPosted: Sun Mar 03, 2013 9:07 am    Post subject: Reply with quote
The zx9r spring feels harder than the Paioli spring when I compare them.
The way I compare the springs was just by feel the strength in my arms and that isn’t a scientifically proven experiment. Wink
Maybe if some one is doing this modification …(Oily)… can compare the springs.
Place a weight on the spring, measure the spring, place the same weight on the other spring and measure again… than we know what spring is the softer one.
Or maybe my Paioli spring has some fatigue problems…. Or the zx9r spring isn’t original
Or…..damned…now I have more questions…… Question Question
Thanks guys… now I can not enjoy my free day with all those questions in my head… Sad
vince
Hursty
PostPosted: Sun Mar 03, 2013 9:15 am    Post subject: Reply with quote
My new WP 9.5 springs with nylon spacers are much better for me and its still quite soft (as requested)
Cool
Hursty from kiwi land Smile
PostPosted: Sun Mar 03, 2013 10:02 am    Post subject: Reply with quote
Cool
Pictures and dimensions please… Wink
vince
Hursty
PostPosted: Sun Mar 03, 2013 10:07 am    Post subject: Reply with quote
Pic on page 15 of my blog Very Happy
But not sure of the full spec's
Not that expensive compared with everything else I've spent Cool
