Rear wheel torque settings?
zokdb7
PostPosted: Sun Mar 17, 2013 8:22 am    Post subject: Rear wheel torque settings? Reply with quote
Hi all,
Can someone please give me the torque setting for the rear wheel
Axle on the db7??
Thanks in advance
Q!uinny
PostPosted: Mon Mar 18, 2013 11:56 am    Post subject: Reply with quote
Hi The DB8 is 100Nm if thats any use.
If your in front your about to be lapped !
PostPosted: Mon Mar 18, 2013 12:03 pm    Post subject: Reply with quote
Yeh, I can also confirm that from the db7workshop manual
zokdb7
PostPosted: Mon Mar 18, 2013 8:23 pm    Post subject: Reply with quote
Thanks ppls so that's 100%
Anyone else got any input ?
Because I've been told different from others but what you are
Saying sounds right?
PostPosted: Mon Mar 18, 2013 8:50 pm    Post subject: Reply with quote
Jeeso Zok , you take some convincing, the later models Db5 and Db6 have a sticker on the ergal drop outs marked 100Nm torque settings
Page 108 of the American Version of the DB7 Owners Handbook extract as below, direct cut and paste:-
5. Tighten the rear axle rod at the torque of 100 Nm. If you have not a torque wrench, contact immediately
your Bimota dealer to verify the installation is made in the proper way.
Let me know if you need an English Version of the Owners Manual sending through to you
zokdb7
PostPosted: Tue Mar 19, 2013 9:48 am    Post subject: Reply with quote
Lol ur too funny!!
Thanks mate I've already done the adjustment..
Thanks again to all,,
PostPosted: Tue Mar 19, 2013 10:39 am    Post subject: Reply with quote
F.T
You know what that means in Australian don't you? I've never used a torque wrench on an axle bolt on any of my bikes over the last 25 years or so.
zokdb7
PostPosted: Tue Mar 19, 2013 10:58 pm    Post subject: Reply with quote
Does the back wheel come lose??
PostPosted: Tue Mar 19, 2013 11:48 pm    Post subject: Reply with quote
Does FT mean F'ing tight or Finger Tight? Would probanly love to tighten to 100Nm but from recollection my torque wrench only goes to 70Nm...minor bolts are done on wrist pressure with an extra flick to be sure...worked so far. You only have to snap a few bolts in your lifetime before your arm realises when enough is tight enough Laughing
PostPosted: Thu Mar 21, 2013 2:35 am    Post subject: Reply with quote
FT = fucking tight
zokdb7
PostPosted: Thu Mar 21, 2013 11:40 am    Post subject: Reply with quote
um ma his swearing?? lol
