Posted: Wed May 29, 2013 5:59 pm Post subject: |
I use a steel ruler and measure from the end of the swingarm to the start of the adjuster block - when they are both the same measurement and the chain tension is correct, I hold the bottom run of the chain tightly towards the swingarm and tighten the axle. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
