DB2 petcock
ja-jo
PostPosted: Wed Jun 26, 2013 9:48 pm    Post subject: DB2 petcock Reply with quote
Hi all,
I have a problem with the petcock on my DB2SR. It has started to leak. I have changed the o-rings that seals it to the tank, but the leak is the petcock itself. I understand that it may be hard to find any replacement unit? Is there a way to renovate it? Does the internal gasket from a similar petcock fit?
I have an idea to fit a quick connector from a Ducati, but then I need to fabricate a tank-fitting for the connector. Has anyone done this?
Best regards,
/Jan
