Muzza
Joined: 31 Jan 2010 Posts: 31 Location: Darwin, Australia
Posted: Mon Jul 01, 2013 4:27 am Post subject: SB6r rear brake master cylinder. |
Hi.
I am wondering if anyone knows what the Brembo part number is for a seal kit to suit a 2000 Bimota SB6r rear brake master cylinder? What other makes/models use this same master cylinder?
Regards
Murray. |
Posted: Mon Jul 01, 2013 10:31 am Post subject: |
Hi Muzza....these calipers are readily available even new from as little as £25-40...the caliper is also the same as used on Cagiva Mito 125's....but not the same disc (I've tried)...Can pass contacts of persons who sell new, or got to Bimota-parts.de or Armin of DRT Schneider (germany again) they sell new and for the cost, if you could find seal kits they would probably end up costing you pretty much the same as a whole new caliper....These calieprs are the same as on pretty much Every Bimota up to 2000, be it DB2/3/4, SB6/7/7, Vdue, YB's 9-11 etc... |
Muzza
Posted: Wed Jul 03, 2013 3:42 am Post subject: |
Hi 2bims. Not sure if we are talking about the same thing. I am after the master cylinder that bolts to the back of the foot peg hanger.
Would anyone know the Brembo part number for the master cylinder? |
