Posted: Tue Nov 17, 2009 2:02 pm Post subject: SB6 MIRRORS |
Are the same as:
MITO
Commonly thought, the 916 mirrors fit. They do NOT fit
zombie
Posted: Wed Nov 18, 2009 12:31 am Post subject: |
just for the record the 916 mirror glass cerrtainly fits on the SB8R you pull out the old glass then snap in the 916 glass. There is a knuckle/ ball joint inside the mirror.
The plastic bit is not right though -- the profile of the join which connects onto the fairing is wrong its too steep.
Maybe the mirror is ok for other models -- quite sure the glass shape is the same for YB11 and SB8K maybe applies to SB6/7/6r and the other models that use this mirror type.
Zombie. |
Posted: Wed Nov 18, 2009 11:50 am Post subject: |
zombie wrote: |
Zombie. |
Yep, dead right, I've got a 916 glass here and it's a dead ringer for the bimota item. It's the plastic case that doesn't fit. As you say, the profile is totaly different and also curved
So let's get this right, The following Bimota's all use the same mirrors:
SB6
SB6R
SB7
SB8K
YB11
Anyone want to correct this list or add any more |
Seven
Posted: Sun Jan 03, 2010 11:17 am Post subject: |
oily wrote: |
SB6
SB6R
SB7
SB8K
YB11
SB8R & SB8RS
Are you 100% certain about the Mito mirrors fitting? I've tried to purchase some original Bimota ones from the Factory but even they do not stock them any longer
The 916 bodies definitely do not fit as I purchased a pair from Flea Bay and they have 3 fixings at the end instead of the Bimota's 2, therefore requiring the drilling of an extra hole in my carbon fairing which I'm not prepared to do! _________________ Seven |
zombie
zombie
Seven
Posted: Sun Jan 03, 2010 1:05 pm Post subject: |
No they won't fit. On the original Bimota item there are two threads protruding from the mounting end which bolt up onto the fairing. The Mito mirrors have two prongs instead, so they require an extra bolt in the middle to secure them to the fairing...if you look closely you can see the middle thread hole in the mirror. You could fit them but would need to drill an extra hole which would result in 3 holes in the fairing over a 1.5 inch section, which could weaken it somewhat.
Sorry! Looks like we need to keep looking.... _________________ Seven |
Posted: Sun Jan 03, 2010 1:15 pm Post subject: |
Mito mirrors DO fit the SB6
The SB6 fitting IS two prongs with a bolt in the middle. Same as the Mito |
Seven
Posted: Sun Jan 03, 2010 7:15 pm Post subject: |
oily wrote: |
Borrocks Serves me right for having an SB8 then...... _________________ Seven |
Posted: Sun Jan 03, 2010 8:52 pm Post subject: |
ahhhh....your giving up too soon.
wheres your sense of adventure
Have you got a decent picture of the buisness end of a SB8 mirror?
Maybe the two prongs screw out of the mito mirror and could be replaced with bolts or somthing.
would the hole spacings be right? |
sapila racing
Posted: Mon Jan 04, 2010 5:50 pm Post subject: |
oily wrote: |
I could check if the two prongs can be removed form the Mito mirrors as I have a pair at home.
Next week though as I'm in Romania until Friday.
They are exactly the same as the SB6 mirrors, the only difference being that insetad of the 'b' logo they have the little elefant. |
Posted: Mon Jan 04, 2010 6:29 pm Post subject: |
We have a volunteer. Well done Aris but it's a bit pointless until Seven comes back with dimensions/photo/drawing.
I was going to pull a mirror off my sb6 to check, but thought I'd wait until I knew what I was looking for.
The prongs must screw in/out otherwise they wouldn't be made from hexagonal bar (I think)
Seven
Posted: Mon Jan 04, 2010 8:50 pm Post subject: |
The good news is that I will be taking my mirrors off this weekend so I will be able to post some photos of the mounting ends and the fixings, along with the dimensions
The bad news is that the reason for removing the mirrors is that I have noticed a hairline crack in the carbon fairing around the headlamp area, which even though it is practically invisible to the naked eye, I know it's there so it's bugging the hell out of me and I need to get it repaired and re-lacquered ASAP _________________ Seven |
Posted: Mon Jan 04, 2010 8:59 pm Post subject: |
Wow, I felt really sorry for you but at least it's easily repaired.
I then thought of the following joke and nearly wet myself
For some months now I have suspected my wife is having an affair. All the signs are there, she no longer wants sex, stays out most of the night and when i ask where she's been she just says "out with friends". Last night I decided to spy on her. When she came home I hid in the garage so I could see her get out of her car, I watched as she took her underware from the glovebox and put it back on, she then took her wedding ring out of her handbag and put it back on. I quietly peered around my bike for a better view, and it was then that my worst nightmare was confirmed. There's a small crack in the fairing just below the tank, do you think I can repair this myself or do i need professional help ? |
Seven
Posted: Mon Jan 04, 2010 11:32 pm Post subject: |
I've heard that one before in a different guise, but it's still a cracker! _________________ Seven |
