Posted: Thu Sep 05, 2013 8:26 pm Post subject: Any info on DB5R diagnostic device? |
As I live out here in the hinterlands there is a dearth of Bimota expertise. I am contemplating the acquisition of the Bimota diagnostic kit for my bike and I am wondering just what it is capable of in regards to engine tuning, and whether I really need it.
Thanks for any elucidation!
Best, Spike C _________________ Spike C.
1965 Triumph T100SC |
spidermaan
Posted: Fri Sep 06, 2013 1:22 pm Post subject: |
There are two type of systems, do you have wich type of ECU/display?
this?
or this?
_________________ http://bcomebimota.blogspot.it/ |
Posted: Fri Sep 06, 2013 6:20 pm Post subject: |
I have the top one, which I think is by far the most attractive! _________________ Spike C.
spidermaan
Posted: Sun Sep 08, 2013 3:13 pm Post subject: |
ok, you have the Pegaso ECU. I have the software for download the ECU software and I use it to do diagnostic, but with that ECU we have some limit for to do something _________________ http://bcomebimota.blogspot.it/ |
Posted: Sun Sep 22, 2013 10:00 pm Post subject: |
Is it possible to remap this ECU? With the stock Ducati ECU Rexxer makes it pretty easy, but if I want to install a free flowing air filter, like the MWR one that replaces the top of the airbox, the engine would probably be running too lean.
When I acquired this bike a month ago it was running pretty crappy, but a few tanks of fuel with injector cleaner in them has it working quite nicely now and I would like to keep it that way! _________________ Spike C.
spidermaan
Posted: Mon Sep 23, 2013 9:57 am Post subject: |
Yes, it is possible to remap ECU Pegaso, you need Bimota software.
I think, but I never tried, it isn't possible to do with Rexxer.
In my opinion you don't need replace the air filter, because in the DB5 the air filter is just open check it before buy something.
If your bike just had the exhaust system mount i think it isn't necessary to remap the ECU, I think it was just ok.
Perhaps It depends from a old-fuel, with some residue. Use (I don't know how many octane the fuel has in USA) the fuel with more octane don't use every time the injector cleaner _________________ http://bcomebimota.blogspot.it/ |
Posted: Mon Sep 23, 2013 5:50 pm Post subject: |
Thank you for the input, the air filter that I was referring to does not replace the stock one, but replaces the airbox lid, so it increases the opening to the box, in effect.
The injectors seem to be nicely cleaned by the Techron so I will not be needing to use it anymore.
Frankly, with the way that this bike is working now I doubt that I will be doing any more fiddling about with system! _________________ Spike C.
Urpo L
Posted: Fri Nov 08, 2013 2:00 pm Post subject: |
I would have the same questions as SpikeC.
My ECU/display is the lower one.
The bike is 2013 DB5 E. |
spidermaan
Posted: Sun Nov 10, 2013 11:39 pm Post subject: |
Urpo L wrote: |
you have the Walbro ECU _________________ http://bcomebimota.blogspot.it/ |
