YB11 faster and faster feature
zombie
PostPosted: Tue Sep 17, 2013 11:31 pm    Post subject: YB11 faster and faster feature Reply with quote
Yep it is a great but under-rated bimota these days....
http://www.fasterandfaster.net/2007/03/down-memory-lane-bimota-yb11.html
For the record has anyone ever painted a YB11 in Vdue colours. The shape of the bodywork on the two bikes is very similar so a good way to get Vdue aesthetics anyway on the cheap?
PostPosted: Thu Oct 03, 2013 3:54 pm    Post subject: Re: YB11 faster and faster feature Reply with quote
Yeah, i would say no to that!
The YB11 let's it self down for a couple of reasons in my mind. It was the end of the line for the YB series. With out a doubt it had the best engine and carb combination, and the frame was sweet, especially down at the swing arm area where the series needed some beefing
But Bimota chose not to give it adjustable steering rake, and the fixed head is chopperesque, if there ever was such a word... Rolling Eyes
I think it was just Bimota cashing in the last of their YB chips. I don't think they were ever raced? Cheers,
Ralph
bimotabob
PostPosted: Wed Dec 04, 2013 10:04 pm    Post subject: Reply with quote
To be fair i haven't ever seen anyone change the steering angle via different collars in the steering head anyway.
Costs a lot for the bearings on the older YB's but they sit aligned so cheap bearings would have be fine.
More a spiel for the buying public.
YB8EI
PostPosted: Fri Dec 13, 2013 7:52 am    Post subject: Reply with quote
Thankfully all the older YB's came with the spherical bearings fitted, though they don't wear very well with oem grease and most bikes having sat around.
If you have an early YB, make sure you pull the triples, and clean and service the bearings!
As you can see I'm planning on playing with head angles. Interestingly enough, a lot of the motogp teams are raking out their bikes, because the Bridgestone's make so much grip, and they can afford the rake which gives stability at speed, without too much sacrifice in the turns.
I've been running English made Dunlop Ntechs, with a bike that is raked back to 24 degrees, and quite like it. I'm looking forward to playing around with the YB I'm building
bimotabob
PostPosted: Fri Dec 20, 2013 10:01 pm    Post subject: Reply with quote
I read somewhere bimota only claim a degree of change available with a different offset collar.
YB8EI
