Tesikwak
Joined: 05 Sep 2013 Posts: 62 Location: Adelaide, Australia
Posted: Thu Oct 17, 2013 2:34 am Post subject: Bim or Not |
Well here's what I'm trying to do. Starting with a Kwak ZX12R motor, and whether to use a standard frame with integral air-box or use a Yam GTS frame and make a new air-box. Bimota did prototype a Yam with a FZ750 motor using alloy plates so I may chop the Yam frame to mount the front arm onto the Kwak one. This why I've badgering various members for bits, even knackered ones, and drawings. Besides the motor, Kwak and Yam frames, I've been building a collection of potential parts to get started, including a SB6R tail unit which has been around the world, a 1D swing-arm, a mag alloy front rim and a Dymag single side rear arm.
I'll get some pics up when I can sort out the upload routine.
Cheers. _________________ If I don't force my opinion onto others; I expect the same from them! |
Posted: Thu Oct 17, 2013 3:19 am Post subject: |
Sounds like quite a project mate! You have a lot of work ahead of you and a lot of parts to find. Finding the right contacts will be the most important part i guess. I look forward to see the updates
Cheers,
Posted: Thu Oct 17, 2013 6:53 am Post subject: |
hi
I wouldn't bother with the GTS frame- it weighs a ton and you'll have to aluminium weld to modify it.
Sounds like you are going in a similar direction to Steve Lindsell:
http://www.google.de/imgres?sa=X&biw=1366&bih=624&tbm=isch&tbnid=wnoohQerVG24OM:&imgrefurl=http://www.advrider.com/forums/showthread.php%3Ft%3D346658%26page%3D2&docid=mWYdNxbYxcdWTM&imgurl=http://www.wired.com/images_blogs/autopia/images/2009/03/13/ev0rr_05.jpg&w=800&h=533&ei=GXlfUteXFMHXtAbazYCwCw&zoom=1&iact=hc&vpx=412&vpy=135&dur=207&hovh=183&hovw=275&tx=188&ty=109&page=1&tbnh=135&tbnw=213&start=0&ndsp=20&ved=1t:429,r:10,s:0,i:112
He started off with a GTS and replaced everything that wasn't really up to racing.
Frame and front swingarm, which are massively engineered for sports touring.
The secong picture was the first version still with standard parts- to do that, you just need a GTS and strip it and add an Exup engine.
I think aerotech even have race bodywork available.
One year later Steve was racing a Saxon Triumph- for probably good reasons.
Here's somebody else doing a sporty GTS conversion:
http://www.gtsclub.org/forum/viewtopic.php?t=2181&postdays=0&postorder=asc&start=195
all the best
http://thecrankcase.com |
Tesikwak
Posted: Fri Oct 18, 2013 3:22 am Post subject: |
Hi Ian,
Didn't I buy some GTS bits off you thru Ebay, some years ago, when I lived in the UK?
Tesikwak
Posted: Fri Oct 18, 2013 5:06 am Post subject: Bim or Not |
Well we'll see if I've got this sorted!!
Besides Bimota's Tesi, I saw this GPZ and met Karl in 1988.
[img][/img]
[img][/img]
[img][/img]
He used to live up near Crewe. He had some write-ups in Superbike and MCN, and recieved an award for it. _________________ If I don't force my opinion onto others; I expect the same from them! |
Posted: Fri Oct 18, 2013 7:10 am Post subject: |
Tesikwak wrote: |
Hi Ian,
Cheers. |
I suspected it was you.
having trouble remembering your name though . .
The Gpz looks pretty well sorted.
That would be another idea- do something like the Tony Foale Q2:
http://www.tonyfoale.com/Articles/Q2/progres5.htm
similar idea to the GPz- with a single sider on the front.
Posted: Fri Oct 18, 2013 6:27 pm Post subject: |
Some brave and bold engineering here... brilliant! _________________ Bimota DB7, Bimota DB5 Mille, Ducati 916, Ducati M900, Benelli Tornado Tre |
Tesikwak
Posted: Tue Oct 22, 2013 12:55 am Post subject: Bim or Not |
Here's some pictures of some parts I've acquired in pursuit of my project :-
[img][/img]
Like Geekay, I got these discs from Japan.
[img][/img]
An 1D front arm from Italy.
[img][/img]
A mag alloy front rim from Germany.
[img][/img]
A carbon fibre Dymag rear arm from UK; it had been mounted on an Aprillia.
[img][/img]
And this SB6R seat unit came from Brisbane to Adelaide, to Stratford on Avon as hand luggage, then back to Adelaide when I moved House!! _________________ If I don't force my opinion onto others; I expect the same from them! |
Posted: Wed Oct 23, 2013 1:41 am Post subject: |
Mmm, very nice hand luggage mate. Getting some nice bits together... just a few to go _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
