Parking light not working-- never mind!
PostPosted: Fri Oct 18, 2013 11:02 pm    Post subject: Parking light not working-- never mind! Reply with quote
I taped into the parking light to power the relay for my accessory fuse block, and now I have no power to the parking light! The bulb is good, is there a fuse for this light? I am not having any luck sorting the electric diagram in the manual that 2bims sent me. I find it odd that this light is not on any other protected circuit. All of the fuses in the block next to the battery look good.[/i]
It appears to have fixed itself!
Spike C.
1965 Triumph T100SC
PostPosted: Sun Oct 20, 2013 5:22 pm    Post subject: Reply with quote
Parking light? You leave it out on the street in the dark? Surely more harmful than the light not working? tee hee
PostPosted: Sun Oct 20, 2013 8:00 pm    Post subject: Reply with quote
Yar yar!
Butt serially, I was worried that the light being out would mean that my heated grips wouldn't work. It turned out the socket was getting juice, so no worries on that regard, and for some reason the light lights now. It lights with the headlight, so if it is not illuminating you don't have as much headlight light, so oncoming cars can't see you as well!
Spike C.
1965 Triumph T100SC
