Peter SRI
Joined: 14 Oct 2013 Posts: 16 Location: Vorden, Netherlands
Posted: Sat Oct 26, 2013 11:23 pm Post subject: Question about unknown connector YB9SRI |
Hi,
Does anybody know this connector? Has it a function? It's wired at the cable from the CDI and isn't connected. Does the Bike missing something?
Ciao,
Peter
Posted: Sun Oct 27, 2013 8:40 am Post subject: |
I'm pretty sure that's the on board diagnostic plugn to check for Fi faults.
http://thecrankcase.com |
Peter SRI
Posted: Sun Oct 27, 2013 1:58 pm Post subject: |
crankcase wrote: |
Ian |
Hi Ian,
That could be.
Ciao,
Peter |
Posted: Sun Oct 27, 2013 8:41 pm Post subject: |
Youre doing well if theres only one connector that goes nowhere, Bimota use the donor engine and electrics and always end up with several loose connectors that lead to nowhere....the Db series must have 3 or 4, and the Vdue, even though with its own engine has Ducati electrics, and a whole sackful of spare connectors going nowhere...But as crankcase says, seems to lead from the ECU so a fault finder/diagnostics plug in... |
Peter SRI
Posted: Mon Oct 28, 2013 8:40 pm Post subject: |
2bims wrote: |
Hi, thanks. Seems to me as Italian Spaghetti wiring.
Regards,
Peter |
bimotabob
Posted: Fri Nov 29, 2013 12:50 pm Post subject: |
my YB is just a modified Yamaha loom and separate EFI loom.
What computer does your run - is it TDD? _________________ YB8EI |
Posted: Fri Nov 29, 2013 1:11 pm Post subject: |
Peter SRI wrote: |
Hi, thanks. Seems to me as Italian Spaghetti wiring. |
What you don't understand only makes you stronger... I think at least? Therefore i Um-mm. |
