Yb11 lower fork leg neeeded. (clamp side)
PostPosted: Fri Nov 29, 2013 12:43 pm    Post subject: Yb11 lower fork leg neeeded. (clamp side) Reply with quote
Any one have by chance have a accident damaged set of forks for the YB11 or a lower (rh?) leg side with the pinch bolt clamp lower leg side in tact????????
Give me a pm if you have anything, or by all means post here. Smile
PostPosted: Fri Nov 29, 2013 12:47 pm    Post subject: Reply with quote
Don't know if this will help you out any in your search, but the lower YB11 part of the 51mm fork is the same as the sb6 46mm one just different bushes etc.
PostPosted: Fri Nov 29, 2013 1:04 pm    Post subject: Reply with quote
Yes it certainly does. Are parts for these forks available from the manufacturer?
PostPosted: Fri Nov 29, 2013 1:29 pm    Post subject: Reply with quote
Looking at the Paioli web site the forks are still available , so maybe spares are also.
PostPosted: Fri Nov 29, 2013 1:40 pm    Post subject: Reply with quote
I sold a set of these recently, as they don't conform to period 6 requirements racing here in Australia.
To my horror, i didn't notice the crack in the axle clamp Embarassed
I'll refund of course if necessary, but the buyer is keen to make this work. And with out a doubt, so am I.
Thanks for your input Vort.
