V Dues & tuning on the Dyno
Goto page 1, 2, 3, 4  Next
Weed
PostPosted: Sun Dec 29, 2013 7:31 pm    Post subject: V Dues & tuning on the Dyno Reply with quote
Good morning guys, I have just joined up and as usual looking for some information.
I have owned a V Due for nearly 2 years and has been a back ground project since I picked it up. It is FI model & I wanted to keep it that way, so I replaced the original ECU with a MoTec unit and this is where the fun begins.
I have fitted Lambda probes to the exhaust but being a 2 stroke, the results are inconsistent.
The question is, do you guys have any experience tuning 2 strokes on a eddie current brake dyno that you could help me with.
djt77
PostPosted: Wed Feb 19, 2014 5:32 am    Post subject: Reply with quote
Hi Weed,
I see your in Perth as well. Not up to speed on 2 stroke tuners in town but will try and find out for you.
Wasn't aware of any vdue in Perth, would love to check it out some time.
Dan
Weed
PostPosted: Fri Feb 21, 2014 7:48 pm    Post subject: Reply with quote
Thanks Dan. It is not an easy path but we'll get there some how. All in the learning.
It has been suggested that I get hold of someone somehow that races the latest generation outboard boats as they are 2 stroke, fuel injected etc. Lambda readings are only causing confusion due to the oil in the exhaust gas I suspect
Weed
PostPosted: Sun Feb 23, 2014 5:45 pm    Post subject: Reply with quote
Made some progress this weekend mainly with the power valve setting. She certainly is getting my attention now. Just got to finish off the mixtures.
Dan, I'll send you a PM when she is finished
PostPosted: Sun Feb 23, 2014 10:17 pm    Post subject: Reply with quote
Have you cleaned the injectors ?
That could help with the tuning
Trev
Weed
PostPosted: Mon Feb 24, 2014 10:12 am    Post subject: Reply with quote
Trev
Yes mate. Sent them off for cleaning & flow testing. From what I am reading Lambdas don't work to well because of the relatively dirty exhaust caused by the scavenging effect. We are slowly getting there. Played with the power valve settings on Saturday & that got my attention. Good fun. Shocked Very Happy
djt77
PostPosted: Mon Feb 24, 2014 10:13 am    Post subject: Reply with quote
Glad to hear things are moving forward.
Pretty sure you have the only V-Due in WA Smile
Weed
PostPosted: Mon Feb 24, 2014 10:55 pm    Post subject: Reply with quote
Hopefully it will be registered in a month or so
PostPosted: Tue Feb 25, 2014 12:36 pm    Post subject: Reply with quote
Like mine Wink
Trev
Weed
PostPosted: Thu Feb 27, 2014 1:27 pm    Post subject: Reply with quote
trev45 wrote:
Like mine Wink
Trev
I thought yours' was registered Trev.
PostPosted: Thu Feb 27, 2014 11:27 pm    Post subject: Reply with quote
Three years ago now for the first time
and a first for a VDUE in OZ to get rego too
Number plate VDUE of course
Trev
Weed
PostPosted: Fri Feb 28, 2014 10:09 pm    Post subject: Reply with quote
Trev
A fit & proper number plate for her too. I put the fairings on mine last night (have to come off again of course) & they are a truly beautiful little bike alright.
PostPosted: Sat Mar 01, 2014 12:31 pm    Post subject: Reply with quote
Hey you Vdue guys, I don't think I've seen any pics of a Vdue without bodywork. Anyone got any Vdue porn they'd like to share?
djt77
PostPosted: Tue Mar 11, 2014 12:46 pm    Post subject: Reply with quote
Any progress made weed?
PostPosted: Tue Mar 11, 2014 5:45 pm    Post subject: Reply with quote
Just read this one too late.........just finished putting mine back together again so missed my chance.........had to strip the clutch down and clean it out......needs an open clutch cover really to let the clutch material out.....starts to gind and slip after 800 miles or so........THey look a lot like DB4's to be honest Brian when stripped....frame wise that is...and then theres rakes of plumbing and carbon air boxes and intakes and wires and cables everywhere...looks like a plumbers merchants and spaghetto factory blended in a mixer........all engine cases and halves, heads etc are alloy...but have been sand cast to a rough finish and left like that...pretty sure Vort has a picture somewhere of his stripped down......
Page 1 of 4
