Dash / Tacho Combo
Weed
PostPosted: Tue Dec 31, 2013 11:09 am    Post subject: Dash / Tacho Combo Reply with quote
Has anyone had one of the original dashes apart? Neither the Tacho or speed are working. I have been told that it is common for a diode to come lose inside & I need to carry out some repairs.
PostPosted: Tue Dec 31, 2013 9:54 pm    Post subject: Reply with quote
They are very prone to loosing 'segments' of the display.
Probably worth speaking to Piero, especially as you have lost both functions.
SB8R Tuner
PostPosted: Tue Dec 31, 2013 10:17 pm    Post subject: Reply with quote
Is this for an injected or carbureted bike? If it's carbureted, I have two SB8K ecu's apart right now?
Weed
PostPosted: Wed Jan 01, 2014 4:17 am    Post subject: Reply with quote
I managed to get it apart & a capacitor was lying in the bottom of the dash. I will get a new one & fit it up to see if it solves the problems. Thanks for the Piero tip.
cheers
Weed
PostPosted: Wed Jan 01, 2014 4:19 am    Post subject: Reply with quote
She is an injected girlie. Thanks for the offer. As above I will be working on it when the shops open in the New Year
PostPosted: Wed Jan 01, 2014 10:31 pm    Post subject: Reply with quote
Yep the blue diode falls off inside
Trev
Weed
PostPosted: Thu Jan 02, 2014 9:26 am    Post subject: Reply with quote
Trev
Thanks Trev. How is the No1 member of the 2 member Australian VDue club going. Did you have a good Christmas / New Year?
PostPosted: Thu Jan 02, 2014 11:19 pm    Post subject: Reply with quote
But now there is a third member
a mate Pete took one of the carby
ones off me that I built , a all new bike too
He is in QLD
Trev
Weed
PostPosted: Fri Jan 03, 2014 5:21 am    Post subject: Reply with quote
Shit mate, at this rate we will be able to start a movement in the words of Arlo Guthrie Very Happy
I fitted a new diode so the tacho is going round. Are the tachos very flighty for want of a better word or do I still have a problem? It does read RPM ok once the needle is put back on in the right spot but it does waver around a bit.
PostPosted: Fri Jan 03, 2014 12:08 pm    Post subject: Reply with quote
Its a 2-stroke, designed by Italians and an electronic dash....so if its wobbling around a bit youre fortunate that its working.... Laughing
Weed
PostPosted: Fri Jan 03, 2014 10:07 pm    Post subject: Reply with quote
Yes, I suppose the movement I have is better than the movement I had. Very Happy
PostPosted: Fri Jan 03, 2014 10:36 pm    Post subject: Reply with quote
They do move a little bit
But working good stuff
Trev
PostPosted: Sat Jan 04, 2014 1:00 am    Post subject: Reply with quote
I have the later one piece led dash....temp is stuck at 40, low fuel light works, but thats only 70miles anyhow, Speedo at 40 varies between 25 and 70, up to a 100 it can read 190.....so, no idea if its cooking itself, or what the real speed is, but the tachos fine so can time gearchanges ok,,,grateful for small mercies... Laughing
PostPosted: Sat Jan 04, 2014 1:06 am    Post subject: Reply with quote
PostPosted: Sat Jan 04, 2014 3:48 pm    Post subject: Reply with quote
I must be the lucky one, mine works perfect! It's a bugger to read in bright sunlight, but that's not a hassle in the UK!!!
