KB1 rear light
Post new topic   Reply to topic    Bimota Forum Forum Index -> KB Series
repsolmark
PostPosted: Mon Jan 13, 2014 4:09 pm    Post subject: KB1 rear light Reply with quote
Gents just got back on line and have a question for you if I may . The seat unit I have was a replica and came with no rear light or fixings , could any of you advise with pictures what the rear light is from and would you have any close ups so I can see what I need to do.
Also if anyone has pictures of the wiring and a close up of the coil brkt mine is not the same as the ones in the parts manual
Just sorted the electrics which were a mess so at least it now runs and Christ its throaty even with the standard silencer.
Hope someone can help.
Regards
Mark
Current projects the new KB1 as its not as pristine as I was told before buying LOL. Midway into Fritz Egli Honda, CR Rickman Kawasaki still sat on the bench and an F1 Harris Honda which has some interesting racing history.
PostPosted: Tue Jan 14, 2014 12:15 am    Post subject: Reply with quote
Hi Mark
like yours I've take mine apart as I found a couple of bodges I didn't like. I'll sort out some pics of the rear light - only 3 wires go to it and the last owner managed to wire those wrongly! Just for interest do most of the aluminium parts have a circular "bimota patent" logo about 1cm across stamped into them on your bike. does yours have a pipe from the rear engine breather, if so where does it go to?
Assorted Smile
PostPosted: Tue Jan 14, 2014 8:15 am    Post subject: Reply with quote
hi Mark
the rear light was used on lots of Moto Guzzis and Benellis as in later Mk 1 and all Mk 2 Le mans.
Armin has the coil bracket listed:
1 500 004 589 Rahmenverstärkung (Zündspulenhalter) unter Tank 60,00 €
website: http://bimota-teile.de/Bimota/index.html
click Ersatzteile on the left side then choose KB1
but there doesn't look to be stock !
worth an email- he can do English.
I'm sure the wiring loom is from the doner Kawasaki if you need to replace it.
all the best
Ian
http://thecrankcase.com
PostPosted: Tue Jan 14, 2014 4:16 pm    Post subject: Reply with quote
The rear light is very similar to my DB2 light from first look. The wiring loom is a bit trickier as mine is very messy -it depends on the year and whether you have a factory built bike or a kit. My donor engine is from a 1980 K1000A3 model but the wiring does not match that model according to the Kawasaki manual
Assorted Smile
repsolmark
PostPosted: Tue Jan 14, 2014 4:40 pm    Post subject: Rear light Reply with quote
To both of you, many thanks for taking the time to respond.
To Bimotanige I will check if I have the breather pipe and get pics, I will also check the logo thing as well but I'm pretty sure there are numerous items stamped or machined into the ally. It has an ally tank ,goldline Brembos and the six spoke wheels.
Crankcase (Ian) If you can get any pictures that would be great ,then I can check this light unit as per your advice.
The coil bracket I could get re manufactured if I had a donor or drawings with dimensions. I have access to our sheet metalwork and powder coating sister company down stairs, which is handy at times.
Thanks again to you both and my email if its easier is kerimarkh@hotmail.com
Regards
Mark
PostPosted: Wed Jan 15, 2014 10:14 am    Post subject: Reply with quote
hi Mark,
here's an ebay
http://www.google.de/imgres?sa=X&biw=1366&bih=624&tbm=isch&tbnid=75-ijLa0pg1cqM%3A&imgrefurl=http%3A%2F%2Fwww.ebay.co.uk%2Fbhp%2Fbenelli-sei&docid=j3ec4BTIkaKX_M&imgurl=http%3A%2F%2Fi.ebayimg.com%2F00%2Fs%2FMTIwMFgxNjAw%2Fz%2FvqcAAMXQAEFSFGo~%2F%2524T2eC16V%2C!%298E9s4l7%2CpjBSFGo-0Htw~~60_35.JPG%253Fset_id%253D8800005007&w=300&h=225&ei=xk_WUoHxA4WyywOUoYHQAg&zoom=1&iact=rc&dur=426&page=4&start=71&ndsp=26&ved=0CIADEK0DMGA
you only need the lens and internals though, you can surely find a cheaper one as well.
this is the rear light that I have seen on standard KB1s
all the best
Ian
PostPosted: Wed Jan 15, 2014 8:02 pm    Post subject: Reply with quote
hopefully upload a few pics of mine later, and the coil mount
Assorted Smile
PostPosted: Wed Jan 15, 2014 10:05 pm    Post subject: Reply with quote
pics of the rear light unit - there is a CEV number on the rear mounting. Note the inner skin shape in the underseat view. The space for the three connectors to fit is built into the middle
coil bracket
Assorted Smile
PostPosted: Sat Jan 18, 2014 11:16 am    Post subject: Reply with quote
Hi Guys...I have just fitted one of those very lights....same dimensions and outer body that you throw away to my 900SS restoration, to fit a single seat unit bike....slimmer version than the standard ducati item...is identical
Here it is and cheaper than the Guzzi item
http://www.ducati-kaemna.com/catalog/ducati/seats-seatbodys-and-seatcovers/schmales-ruecklicht-fuer-dk-mono-hoecker.html#!prettyPhoto
Small tail light for DK mono seats
Brand
See other products by PureTEC
Delivery Time: on request
Excl. Tax:€58.74 Incl. Tax:€69.90
Post new topic   Reply to topic    Bimota Forum Forum Index -> KB Series All times are GMT + 1 Hour
