tassie v2
Posted: Tue May 21, 2013 10:07 pm Post subject: Anyone tracking their DB7/8 ? |
Like to hear any feed back from track days . I know Grog and Symmo in Australia do, any others out there ???? Be good to get some comparo's. |
Q!uinny
Joined: 11 Mar 2013 Posts: 18 Location: All over Europe
Posted: Tue Jun 18, 2013 7:03 pm Post subject: |
Hi Nurburgring similar times to the GSXR 1000 K7 about 8.30 on a tourist day without doctoring the vid! but feels FAB !! I am sure it will do better when I get used to it. motorcyclemover.co.uk video is zx10. I will put some video on when I return August ish. _________________ If your in front your about to be lapped ! |
tassie v2
Posted: Wed Jun 19, 2013 2:03 am Post subject: |
The RING sounds like fun, does the 8 feel planted at the speeds i've heard one laps at around that track. |
tassie v2
Posted: Mon Feb 03, 2014 10:53 am Post subject: |
Must be some DB7/8 owners out there wanting to share talk about their bike ? |
tassie v2
Posted: Thu Feb 06, 2014 12:15 pm Post subject: |
Best write up i've read so far. My Db8 has the 200hp upgrade in it (183hp & 104pounds torque at rear wheel, running slicks. Xtreme tech shock cant handle the power output . Has anyone upgraded their suspension ? |
djt77
Posted: Fri Feb 07, 2014 7:21 am Post subject: |
Guys who race them in Italy are using diff suspension, think they might be using Maxton? Company called Superbike Mugello |
tassie v2
Posted: Fri Feb 07, 2014 8:31 am Post subject: |
Theyre using Matris. Cartridge kit in the front and a 3 way adjustable mono in the rear. Been talking to them. Good guys.
Front Marzzochi seem good, but the Extremetech is going in the bin. We have tried different Xtremetech shocks, revalving etc, but it cant control massive pump and whallow driving out of corners. (track) . Taking her to Phillip Island Tuesday , going to try an Ohlins TTX . |
Posted: Fri Feb 07, 2014 7:58 pm Post subject: |
tassie v2 wrote: |
Best write up i've read so far. My Db8 has the 200hp upgrade in it (183hp & 104pounds torque at rear wheel |
Tassie, can you tell me what exactly includes this 200hp upgrade... Was that available only trough Australian importer, or is this Bimota factory stuff? Cost? _________________ Bimota DB7, Bimota DB5 Mille, Ducati 916, Ducati M900, Benelli Tornado Tre |
tassie v2
Posted: Fri Feb 07, 2014 10:51 pm Post subject: |
All supplied through the Australian importer FX Powersports. They fitted a limited edition pipe and can, only 30 made. I believe Allan at FX still has one pipe. They then remapped with a factory developed map which was intended for a WSBK entry with a DB8 , (but as you know they are gridding the BB3.)
Then had the map cleaned up on a dyno. I know max dyno figures can be taken with a grain of salt but the first run compared to the tuned run gave me 20hp gain at 6500 rpm . Engine feels more like an I4 than a twin. The TT pipe knocks off about 4kg too. Expect to pay about $6k for the kit. |
Posted: Sat Feb 08, 2014 5:30 pm Post subject: |
Tassie, thanks! _________________ Bimota DB7, Bimota DB5 Mille, Ducati 916, Ducati M900, Benelli Tornado Tre |
