Bimota DB6R Running Rich
rocketrod
PostPosted: Thu Feb 13, 2014 10:27 am    Post subject: Bimota DB6R Running Rich Reply with quote
I was just wondering if anybody could give me a little help with my 2008 DB6R for some reason it has just started running very rich the four plugs are pitch black mind you they are dry I had it put on a gas analysis machine today and both cylinders are running at 10% C02 when apparently they should be 5% the air bleed screws weren't making any great difference either wondering if anybody has any experience with this the bike only has 3000klm on it and was running really well up until last week when I replaced the battery.
Thanks
Rod Confused
PostPosted: Thu Feb 13, 2014 11:51 am    Post subject: Reply with quote
I dont suppose you have the connecting lead to link it up to a laptop do you? And the Walbro ECU software from Bimota that allows interrogation? Theres a blank lead on the right side beneath the Oil cooler fairing side panel.....
PostPosted: Thu Feb 13, 2014 7:20 pm    Post subject: Reply with quote
If it started running poorly after you did something I would be inclined to go over the last proceedure very carefully. When something changes right after you do something, look to what you just did!
Spike C.
1965 Triumph T100SC
