Rear axle SB6
PostPosted: Fri Mar 07, 2014 1:01 pm    Post subject: Rear axle SB6 Reply with quote
I’m in need of a SB6 rear axle.
If you have one in stock or you know where I can find one please let me know, I will be grateful..
vince
Hursty
PostPosted: Sat Mar 08, 2014 6:56 am    Post subject: Reply with quote
What's up Vince
Have you polished it so much it's out of spec?
Or is it just not perfect like the rest of your bike Smile Wink
Hursty from kiwi land Smile
PostPosted: Sat Mar 08, 2014 11:19 am    Post subject: Reply with quote
I'd try contacting Armin of DRT Schneider...he hasnt any listed on his site...but he always seems to have a way of finding such things
http://www.bimota-teile.de/Bimota/index.html
Or Try Rudolf of Bimota-parts.de.....
http://www.bimota-parts.de/en/?gclid=CPfG8rGdlqECFQc9lAodpCd2OQ
Email both in German with the part number if you can...or at least describe....I've used both before and they are good
PostPosted: Sat Mar 08, 2014 11:50 am    Post subject: Reply with quote
Hursty wrote:
What's up Vince
Laughing Laughing Laughing Laughing
Hursty, You have a very good judgement. Laughing
It’s true, it’s not that the axle is broken or badly damaged.
But my bike didn’t give any problems or things to solve so I was looking for small things or annoying things. And they promise me that when you buy a Bimota you will always be busy with maintenance. So not true … Laughing
The story with that axle is: after I adjusted the chain and torqued the axel is was slightly of alignment.
Only seen when is checked with a laser … (I know I know it’s a bit over the top). Rolling Eyes
And also with installing the axle I found that I need to use much force. From experience it has to go smooth.
So this winter period I take a closer look at all the parts that are involved with chain adjustment and I found that the rear axle is slightly bend and the chrome layer is blistering. That’s why I want a new axle.
And maybe the problem isn’t a new axle … I’m in need for a new Bimota to modified again to satisfied my needs … maybe a DB this time.
Only my wife thinks I’m in need of psychiatric help. she let me not buy a other Bimota.
And what about you, I was hoping to see this winter pictures of your bike in kiwi-land panorama.
What’s wrong, No time to ride your Bim?
vince
PostPosted: Sat Mar 08, 2014 11:51 am    Post subject: Reply with quote
Thanks, I'm on it.
vince
PostPosted: Sat Mar 08, 2014 12:33 pm    Post subject: Reply with quote
There is this new one on Ebay....a titanium Corse one...steep at 349 eruos...but was 699 New...I know that this ebay dealer sometimes takes offers..........
http://www.ebay.de/itm/Corse-Vorderachse-Titan-Bimota-SB6-SB7-/370701445687?pt=Motorrad_Kraftradteile&hash=item564f872a37
Oh...if you find a Sb6 rear spindle...may be best to renew your wheel bearings also...if the old spindle was bent then the bearings may have had a hard life in dealing with the wheel not running true......The Cush drive also has a couple of bearings in it...all should have numbers on the outer face and easy enough to locate replacements
PostPosted: Sat Mar 08, 2014 12:37 pm    Post subject: Reply with quote
You could probably get one made, it could be cheaper and better than an original.
PostPosted: Sun Mar 09, 2014 10:10 am    Post subject: Reply with quote
Hi Steve,
The axle on EBay is a front axle. And to expensive. Shocked
It’s good you mention the bearings, I was in doubt about the bearings.
I had already inspect them and they look fine, but as you say they had a hard life and it’s easy to find new ones and to replace. Better safe than sorry.
Thanks, my doubt is gone. Wink
vince
PostPosted: Sun Mar 09, 2014 10:11 am    Post subject: Reply with quote
And made of Titanium. Cool
vince
PostPosted: Sun Mar 09, 2014 11:41 am    Post subject: Reply with quote
How about a group buy to see if the cost could come down ?
PostPosted: Mon Mar 10, 2014 4:10 pm    Post subject: Reply with quote
Hi Vince.
I can get you a brand new one for €95 plus postage , not sure what the postage will be as don't know where you are.
If you would like it I need to know ASAP so I can order it.
PostPosted: Tue Mar 11, 2014 9:57 am    Post subject: Reply with quote
Hi Vince.
You have pm. Wink
vince
PostPosted: Tue Apr 22, 2014 10:28 am    Post subject: Reply with quote
New axle installed
Test ride successfully Very Happy
Thanks to vort28
vince
PostPosted: Wed Apr 23, 2014 10:44 am    Post subject: Reply with quote
Just glad I could help Vince. Got to keep those glorious SB6's running.
