Delivery of my V Due from Italy
Goto page 1, 2, 3, 4, 5, 6  Next
mm500
PostPosted: Sat Mar 08, 2014 8:18 am    Post subject: Delivery of my V Due from Italy Reply with quote
Got my bike delivered from Piero yesterday Smile
mm500
PostPosted: Sat Mar 08, 2014 8:20 am    Post subject: Reply with quote
I'am installing the original exhaust this weekend before I show it to the DMV on monday Razz
PostPosted: Sat Mar 08, 2014 9:11 am    Post subject: Reply with quote
Excitement levels at 11 Very Happy
Stunning. Enjoy.
PostPosted: Sat Mar 08, 2014 11:04 am    Post subject: Reply with quote
Very nice indeed...and with the added extra of the fuel tap on the left....take your time re-fitting the standard pipes....they need to be fitted to the seat unit off the bike then put them on the bike to the headers....And if your DMV is anything like the UK one you'll need to fot them....noise levels of the Jolly Motos are 105-110Db at half revs of full power...4500 revs...
With the standard pipes you should creep under the 100Db limit (or at least thats what it is in the UK at the test...)
PostPosted: Sat Mar 08, 2014 12:38 pm    Post subject: Reply with quote
Very nice mm500. Did the crate have the bimota logo on the side? I'd so like to have an original bimota shipping crate... Especially if it had an original bimota inside Laughing
mm500
PostPosted: Sat Mar 08, 2014 12:45 pm    Post subject: Reply with quote
brian, yes it did.
2bims, as long as the original exhaust is fitted they don't check the Db Smile
PostPosted: Sat Mar 08, 2014 1:05 pm    Post subject: Reply with quote
How would they know which is the original exhaust then? Cant imagine they will have seen many Bimota Vdues in Norway........
Our UK Standard yearly test does not test the Db levels...but may put advisories on the certificate to protect themselves if they appear "noisey"...Meanwhile the test for newly imported bikes does test the Db levels with the engine at half revs of full power.....Although for V-dues...as long as you can convince them that the bike is over 10 years old...such test is not needed...just a simple MOT....
mm500
PostPosted: Sat Mar 08, 2014 1:17 pm    Post subject: Reply with quote
E3 markings on the exhaust Smile
PostPosted: Sun Mar 09, 2014 12:51 pm    Post subject: Reply with quote
Love it good to see one more for the road / track maybe
Trev
mm500
PostPosted: Wed Mar 12, 2014 5:45 pm    Post subject: Reply with quote
everything went smooth at the dmv Smile
changing tyres to Michelin Pilot power 3 and painting the wheels black
PostPosted: Wed Mar 12, 2014 6:12 pm    Post subject: Reply with quote
Looking good...and will be better with the shiney black wheels...and Jolly moto pipes...take it easy until you get used to it........and once you've mastered it.....sweet.....found anything that doesnt work as it should yet?
First gear can be tricky to get away...and if you stall it...it wont start in gear...even with the clutch pulled...you have to ensure its in neutral, and the neutral light is on (because you can get one or the other at times...but both are needed)...the rear sprocket hub assembly is normallt silver even with black wheels...may look good in black also though?
mm500
PostPosted: Wed Mar 12, 2014 6:43 pm    Post subject: Reply with quote
everything works as it should Smile
I had to use heat to get the front disc of the wheel, do to treadlock.
I need to figure out a solution with the front bellypan screws rubbing against the carbon airbox on bouth sides.
PostPosted: Wed Mar 12, 2014 8:18 pm    Post subject: Reply with quote
Thats a good sign on the front discs.....when I checked mine they were only finger tight........Oh eh......
Oh the belly pan screws....you may find several different lengths of screws holding all the bodywork in....but all the same diameter and thread.....on the belly pan the shorter length is sufficient...and should clear...or put protective sticky rubber pads on the areas where the screws meet........But oh my....arent you "prescious" with your new toy?? Laughing
Thinking about it...and looking at the carbon air box...each of them has "dimples" 2 No...that must be there to accommodate the screws...so if yours are touching then change for shorter ones...simples
mm500
PostPosted: Wed Mar 12, 2014 8:30 pm    Post subject: Reply with quote
I will do that, thanks for the tip Very Happy
mm500
PostPosted: Wed Mar 12, 2014 8:34 pm    Post subject: Reply with quote
yes I'am very prescious with all my italian toys Wink
Page 1 of 6
